spark plugs ???? #731955 06/18/06 01:41 PM
I
itswrongway Offline OP
I saw a new spark plug in auto zone on saturday.we all seen the single prong tip and the double. this one made by bosch platnum has 4 prongs.does anyone know if this kind of plug really is better than the double prong ? will it help burn the fuel better? will it help fuel mileage ?
Re: spark plugs ???? [Re: itswrongway] #731956 06/18/06 02:44 PM
DamKia Offline
Kia Moderator
Re: spark plugs ???? [Re: itswrongway] #731957 06/19/06 09:01 AM
Axe Man Offline
Kia Moderator Emeritus
You can use OEM resistor plugs, single electrode plats, +2 plats, or +4 plats. The DOHC engine isn't too picky on plug type as long as it's the correct heat range.
Whether these +2 or +4 plats buy you any additional power is very debatable. IMHO they don't.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: spark plugs ???? [Re: Axe Man] #731958 06/19/06 01:10 PM
Dave Scott Offline
not really, but they make me feel better.
Re: spark plugs ???? [Re: Axe Man] #731959 06/20/06 12:17 AM
turtleskia Offline
they don't add power, they insure that there will be a consistent spark.
Re: spark plugs ???? [Re: turtleskia] #731960 06/20/06 08:00 PM
wd8cdh Offline
Since the Sporty uses wasted spark, make sure that the plugs have platinim on BOTH the center and the ground electrodes, not just the center electrode.
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6090 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-11-02 21:46:34 UTC
