How do you remove the rear side windows on a 2nd Gen 4Runner? #732380 06/20/06 10:03 PM
5
5VZ Offline OP
Not the door windows - the rear cargo area side windows. The moulding is bolted on, but seems to be glued in too?
Thx
94 4Runner, 5VZ-FE, A340H
Re: How do you remove the rear side windows on a 2nd Gen 4Runner? [Re: 5VZ] #732381 06/21/06 02:39 AM
ldivinag Offline
from my memory of reading the FSM, the window is bolted to the body and maybe some kind of sealant...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: How do you remove the rear side windows on a 2nd Gen 4Runner? [Re: 5VZ] #732382 06/23/06 06:16 AM
CORunner93 Offline
....remove it CAREFULLY!
Most non moving windows are installed with a sealent. Even if it's in a frame, the frame will have a sealent between the frame and the body to prevent leaks and whistling noises. You'll have to cut through the sealent...with a really thin blade knife.....or preferably a hot knife....and use a little gentle prying and proping up of the cut sections.
You can get a hot knife at a decent tool shop. It's like a knife...usually the blade is bent at a 45 degree angle about half way down and when you plug it in, it heats up.....and melts the seal.
Be careful though, it's easy to slip and cut yourself....and those windows are heavy.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: How do you remove the rear side windows on a 2nd Gen 4Runner? [Re: CORunner93] #732383 06/27/06 08:59 PM
5
5VZ Offline OP
Thanks for the tips.
Re: How do you remove the rear side windows on a 2nd Gen 4Runner? [Re: 5VZ] #732384 07/02/06 10:41 PM
lethe Offline
you can do what my buddy did, hit a tree. <img src="/forums/images/graemlins/smile.gif" alt="" />
87' ext cab toy
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.016s) Memory: 0.6065 MB (Peak: 0.6704 MB) Data Comp: Off Server Time: 2026-11-02 03:00:44 UTC
