2002 rodeo #732407 06/21/06 03:07 AM
travsdad Offline OP
My 2002 on 2 occasions would not idle to speed for a few mins cutting off as soon as i let of the gas then was fine tonight though it had no power and the check engine light cam on a reduced power light was on for a few mins i cut it off and recranked the reduced power went out but not the check engine light normal power was back as well it just turned 40k miles <img src="/forums/images/graemlins/confused.gif" alt="" />
Tom Hood
Re: 2002 rodeo [Re: travsdad] #732408 06/24/06 09:33 AM
NATO308 Offline
Oxygen sensor, fuel regulator, have the code read to find out why the check engine light is on.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: 2002 rodeo [Re: travsdad] #732409 06/24/06 05:08 PM
JLEMOND Offline
HAVE THE THING SCANNED AND SEE WHAT IS HAPPENING, BUT IT SOUNDS LIKE THE ACCELERATOR PEDAL POSITIONING SENSOR UNDER THE DASH IS TAKING A LAST BREATH , THIS IS A DRIVE BY WIE SYTEM JERRY
Re: 2002 rodeo [Re: JLEMOND] #732410 06/24/06 05:57 PM
travsdad Offline OP
yeah im gonna invest in a good code reader to see what it is so far its been fine for the last few days
Tom Hood
Re: 2002 rodeo [Re: NATO308] #732411 06/25/06 09:10 PM
travsdad Offline OP
acted up today when in park the idle would go from 0 to 2000 and back over and over put it in gear its fine wierd is all i can say
Tom Hood
Re: 2002 rodeo [Re: travsdad] #732412 06/26/06 02:56 PM
NATO308 Offline
My wife's 2001 was doing the same thing, revving to around 2000 for no reason. Turns out it was a combination of bad gas and wrong O2 sensor. After July 2000 Isuzu changed the O2 sensors. With an older, 98-2000, sensor in there it goes bananas and does not know what to think.
Re: 2002 rodeo [Re: travsdad] #732413 06/26/06 04:19 PM
TrailMystic Offline
Is your 2002 still under full powertrain warranty? If so, it seems like your issues would be included. The dealership recently replaced my intake manifold gasket and my fuel pump/sending unit - all covered under warranty.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: 2002 rodeo [Re: TrailMystic] #732414 06/26/06 10:29 PM
travsdad Offline OP
I assume it is it only has 40k miles im sure its a sensor of which only a code reader will tell good thing the 02 sensor on it is not as expensive as on my pathfinder
Tom Hood
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6197 MB (Peak: 0.7021 MB) Data Comp: Off Server Time: 2026-06-17 10:29:38 UTC
