check engine light,code p0171 #732729 06/22/06 03:27 AM
my check engine light came on and i retrieved a code p0171.i have a 2000 prerunner with a v6 and automatic.105,000 miles.bought it used and it had 93,000 on it.i had the timing belt,pulleys,waterpump,thermostat ect. replaced right after i bought it,i also put a k&n airfilter in about 4000 miles ago and was reading about that and some of its problems in here.i cleared the code and the light hasnt come on but its only been a day,i know things dont fix themselves.any ideas,thanks
Re: check engine light,code p0171 #732730 06/22/06 04:02 AM
52degrees Offline
P0171= fuel trim lean, bank 1.
Did you by chance recently oil your K&N?
KG6VNX
Re: check engine light,code p0171 [Re: 52degrees] #732731 06/22/06 04:08 AM
no,its only got about 4000 miles on the filter
Re: check engine light,code p0171 #732732 06/22/06 05:31 AM
Its your MAF sensor, Try cleaning it with the recomended procedures under the 30K maint. list. otherwise I had the same code about 5 months ago, ended up replacing the whole sensor. These tacomas are really sensitive when it comes to foreign matter on the sensor, basically the sensor works on electrical resistance, i.e. the more dirt, dust etc.. that collects the hotter the resistance and thus throwing a code on the computer, try cleaning if not replace.
Re: check engine light,code p0171 #732733 06/22/06 11:13 AM
bard Offline
It could also be the front O2 sensor. They do go out and it's cheaper than a new MAF. But clean the MAF sensor first as suggested earlier since that's the cheapest option.
Re: check engine light,code p0171 [Re: bard] #732734 06/22/06 02:17 PM
thanks for the suggestions,ill clean it tonite after work.where is the front o2 sensor located?
Re: check engine light,code p0171 #732735 06/22/06 07:38 PM
bard Offline
In front of the cat. Are you sure you know how to clean a MAF? Break an element and it's toast <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: check engine light,code p0171 [Re: bard] #732736 06/23/06 02:19 AM
ive got the cleaner and the tools to do it so ill give it a shot.ive worked alot on older trucks,just not real knowlegable on newer trucks with computers.thanks
Re: check engine light,code p0171 #732737 06/23/06 02:33 AM
52degrees Offline
BTW, K&N filters cause drivability problems. The oil gets on MAF sensor wires and insulates them, causing them to give false airflow readings.
There are also many studies that indicate that K&N air filters allow a lot more dirt to pass through than paper filters. Toyota makes about the best air filter out there, in my professional experience (I'm a licensed smog tech in Kalifornia and an ASE Master tech).
My best advise to anyone with a Mass AirFlow sensor (MAF) is to stick with the factory paper filter and stay as far away from K&N filters as humanly possible.
KG6VNX
Re: check engine light,code p0171 [Re: 52degrees] #732738 06/23/06 12:52 PM
Dandeman Offline
Toyota Moderator
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6299 MB (Peak: 0.7506 MB) Data Comp: Off Server Time: 2026-06-09 18:21:55 UTC
