elect ? #733133 06/24/06 03:43 AM
tgzzzz Offline OP
Should an 82 22R continue to run when you pull a battery terminal off? With one Voltage reg, it stutters but keeps
running. With another voltage reg, it shuts down immediately. What's up with up that?
87 JX Zuke bone stock almost cherry
86 Heavy Chevy 350 one ton 26' RV
There's always time to do it over.
Re: elect ? [Re: tgzzzz] #733134 06/24/06 05:34 AM
2ndGenToyotaFan Offline
uuuhhhhhhhhh it should die..... Sounds like the voltage regulator is holding a charge enough to let it run a little..... wierd
Jerod
89 4Runner, 282k miles. "I gotta have more cow bell"
Re: elect ? [Re: tgzzzz] #733135 06/24/06 06:06 AM
A
AUSSiE78 Offline
my friend once had a firebird and we would boost it to start it (had no battery) and run it around in his parents field! Granted it would only run for about a minute or so.... but it did run.
I don't know if the 22R would do the same thing but... I would think the alternator would keep it running for a while until it burns out.
AUSSiE
'88 4Runner
3.0, mod'd intake, dynomax exhaust, everything else stock.
Life will always go on....
Re: elect ? [Re: AUSSiE78] #733136 06/24/06 06:28 AM
trythis Offline
I was working on my 22re the other day and took the (-) cable off the battery for something, it kept running, is that something I should look into? I wopndered about why it didnt shut off, but then I didnt know why it wouldn'd either.
Re: elect ? [Re: tgzzzz] #733137 06/24/06 06:54 AM
eightyeight Offline
most older cars will run without the battery connected as long as the alternator is good. i guess its all how its wired.
when the truck shuts down, that voltage regulator must be bad. the truck is just running off the battery, and when you disconnect it, it dies. obviously.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6021 MB (Peak: 0.6661 MB) Data Comp: Off Server Time: 2026-06-21 17:50:08 UTC
