You have got to see this!! Pics... #733736 06/27/06 03:31 AM
79Toy4x4 Offline OP
well i drivin my truck down an old country road in the middle of nowhere when the engine died and rear tires locked up. after walking for a mile or two i got to a phone, towed it home and pulled the head to find this
never seen anything like it before. both valves stuck completely in the head/block. so i'm to the point where i might part the truck out here soon along with my other 2wd in the back yard. I have tons of parts from different years all over in the garage so watch the for sale section here in the next week or so. gunna sell stuff cheap to get rid of it.
[Linked Image]My engine before...
Re: You have got to see this!! Pics... [Re: 79Toy4x4] #733737 06/27/06 03:37 AM
lethe Offline
i've heard of people having similar things happen because they are on the free was and instead of shifting into 4th they go to second and their engine see's 10k rpm. Or my buddy had a porsch 944 and they timing belt tensioner broke so the cam went cray and punched the valves through a few pistons.
87' ext cab toy
Re: You have got to see this!! Pics... [Re: 79Toy4x4] #733738 06/27/06 03:45 AM
kewlynx Offline
Daaaang...I'd put that up there with the picture I got from a guy who had the crankshaft whack his oil pump and the TC cover. <img src="/forums/images/graemlins/zombie.gif" alt="" />
No noise or trouble before it failed?
**ubi apis- ibi salus**
Re: You have got to see this!! Pics... [Re: kewlynx] #733739 06/27/06 03:54 AM
79Toy4x4 Offline OP
not really any indication just one lil odd sputter taking off at a stop sign an hour before. but i was runnin a holley 500 on it so i didnt think anything of it but thought i gave it too much gas at first. that engine ran great with that carb after 1200 rpms giving the best throttle responce i could ever expect. but otherwise nothin. no unusual noises, feelings, reactions.
Re: You have got to see this!! Pics... [Re: 79Toy4x4] #733740 06/27/06 04:00 AM
eightyeight Offline
ummmmm.....
did your timing chain break?
did a valve spring (or 2) break?
something let go, this dosent just happen...
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: You have got to see this!! Pics... [Re: eightyeight] #733741 06/27/06 06:37 AM
kyle-22r Offline
looks like a couple dropped valves if you ask me. the retainers either failed or somehow got loose and the valves went bye-bye down the holes.
pity it had to happen on such a clean engine!
'91 4x4 shortbed
22R-E, W56, the dd!
Re: You have got to see this!! Pics... [Re: kyle-22r] #733742 06/27/06 01:06 PM
ToYPU Offline
rip that piston out, pull the head off ur 2wd (pull a pisont n rod assembly too) hone the cyl THEN finally...be on your merry way!
kevin <img src="/forums/images/graemlins/notooth.gif" alt="" />
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
Re: You have got to see this!! Pics... [Re: 79Toy4x4] #733743 06/27/06 03:17 PM
Stevie Offline
Something similar happened to me. Decided to keep the old exhaust valves on a rebuild. As penny-wise and dollar foolish proved about 100 miles after, heard a little ping, then a bunch of engine ratteling after comming out of a street corner. Destroyed head, piston(s), metal contamination, etc. All for trying to save a few bucks! <img src="/forums/images/graemlins/scared.gif" alt="" />
'80 4X4 Longbed
Re: You have got to see this!! Pics... [Re: ToYPU] #733744 06/27/06 11:42 PM
79Toy4x4 Offline OP
rip that biotch outta the piston, pull the head off ur 2wd and be on your merry way!
lol <img src="/forums/images/graemlins/zombie.gif" alt="" />The valve slpit the piston right down the middle if you can see in the picture, scored up the block too much. as far as what happened i dont know. #1 it wasnt the valve keepers or spings. didnt know it was that bad before pullin the head untill i tried takin out the spark plug and half was gone and i could see the valve in the hole. took off the valve cover and all looked normal, valve shaft, and spings still in the right place.
[Linked Image]how it looks. competely normal so it wasn't spings/keepers they're still in the right spot
#2 timing chain looks good, although i havent tore it down to see the crank gear yet. who knows i'm gunna take apart the block to see the rods and crank gear, maybe that will be the clue
Re: You have got to see this!! Pics... [Re: 79Toy4x4] #733745 06/28/06 01:34 PM
ToYPU Offline
ok i fixed my post...
if you spin the crank does that piston go up n' down <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
* New mods *
  • minor body work
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6394 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-11-02 03:00:53 UTC
