I need Starter troubleshooting for a 86 4-Runner Please... #733892 06/27/06 08:47 PM
OK, the starter was put on new by a reputible company around a year and a half ago. One month after they put it on, I was having to beat on it with a hammer in order for it to crank. I have been doing this all this time, for over a year and a half. Sometimes it cranks, and other times I have to beat on it with a hammer.
I got a new starter. I took my 4-Runner to my Dads for him to put it on for me. I didn't have to pay anything for the starter since it was under a lifetime warranty.
Instead of just simply putting the starter on for me, he cleaned some wires, and reconnected them or something, and said there was nothing wrong with my starter. OK, so trusting him, I had my truck back, went to the store, and when I went to leave, it would not crank, so I had to beat on the starter to get it to crank.
Now he seems to think it might be the relay, but we dont know where the relay is located for the starter. Is the relay in the starter or on the firewall or somewhere else? It's an 86 4-Runner 22RE Five speed manual trans. We have a Haynes manual but it does not tell where the relay for the starter is located.
I really need to know where this relay is located. Please can someone tell me?! I have to have my truck fixed in less than a week to go see my Grandma who lives two hours away because my Grandpa just died recently and she desperately needs my help.
Other than telling me where the relay is located, what other advice can yall give me? Honestly I think my Dad should have just put the new starter on it. But what do yall seasoned mechanics think?
Thanks a bunch,
~Rebelbelle~
Re: I need Starter troubleshooting for a 86 4-Runner Please... #733893 06/27/06 11:03 PM
DRTDEVL Offline
The contacts are bad in the starter solenoid. Does it go "click" when you try to crank it (just one click, then nothing else)? If so, replace the contacts in the starter.
Another common area is corrosion INSIDE the battery cables. You said your dad had to clean connections? Were they covered in corrosion? If so, change the battery cables, too.
There is no relay in your starter system, IIRC. If so, it is underhood on the r/s fenderwell behind the fusebox, and is copper in color. These almost never fail, so look elsewhere.
We need more info... 1 click, or nothing at all? Everything else dies, or nothing changes. My money is on the cables or the contacts in the starter solenoid (both very cheap to fix).
Re: I need Starter troubleshooting for a 86 4-Runner Please... #733894 06/28/06 01:59 AM
Adam F Offline
Here's an hour or 2 of reading material.....
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
If your faced with replacing the starter again, honestly, I would buy a junkyard TOYOTA Denso starter and replace the contacts. No reman parts store starter are as good as a OEM unit.
97 4R, stock, daily driver
Re: I need Starter troubleshooting for a 86 4-Runner Please... [Re: DRTDEVL] #733895 06/28/06 06:59 AM
Thank you, I will let my Dad know this information, and find out what he cleaned, and let yall know.
Thank you so very much!
~rebelbelle~
Re: I need Starter troubleshooting for a 86 4-Runner Please... [Re: Adam F] #733896 06/28/06 07:04 AM
chuckles Offline
junk starter from bone yard....... 20 bucks.......
Starter contacts from Toyota..... 12 bucks.......
1 hour to replace contacts..... 30 bucks.......
knowing you did not get ripped off by some feckless AutoZone rebuilt POS part......... PRICELESS!!!!!!
Re: I need Starter troubleshooting for a 86 4-Runner Please... [Re: chuckles] #733897 06/28/06 06:54 PM
I havent spoken with my dad yet, but I wanted to let yall know...
When it does not start, everything comes on as far as the radio, lights, etc. When I turn the key over, there is one clicking type sound, and everything goes dead when I turn the key over.
My Dad gave me a wire to start it with with also. He showed me how to take this wire, touch it to one of the battery terminals, then to take the other end of the wire, open up one of the connectors going to the starter and touch that wire, and that starts it.
After reading some of the mateiral in the link you gave me, I believe I have a solenoid problem.
I dont have time to wait for the parts to come in to fix the starter, and I wouldnt want to replace the parts in the one on it because its not a toyota starter, and I have no idea what brand they put on it when they replaced it.
I think my best bet is to take my chances and go see my Grandma. Park on hills, and use the wire that my dad gave me.
Then when I get back, hunt down a junkyard, get a toyota starter, and if it aint any good, then replace the contacts in the starter solenoid.
Thank you so much for your help, and any further advice is much appreciated.
~rebelbelle~
Re: I need Starter troubleshooting for a 86 4-Runner Please... #733898 06/29/06 02:39 AM
kewlynx Offline
Also there young lady for your info-- you can always ask the parts store to bench check your OWN rebuild-- just tell them you need to check it out.
ALWAYS get battery, starter, and alternator bench checked BEFORE leaving the store; saves you the headache and the time. This just makes you a better consumer. <img src="/forums/images/graemlins/kewl.gif" alt="" />
www.car-part.com bookmark it. <img src="/forums/images/graemlins/smile.gif" alt="" />
Only other thing I can think of is the ignition switch headed south. Linky in the Toyota maintenance section; link in header.
Have a safe trip, and just let your Gramma ramble if she needs to.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.010s) Memory: 0.6160 MB (Peak: 0.7083 MB) Data Comp: Off Server Time: 2026-11-17 06:12:35 UTC
