Re: Let's talk about deep water [Re: RobG] #734125 06/30/06 03:09 PM
rodeoredd Offline
i have been wracking my brain trying to figure out a type of shield after my alt. kicked it last month.
no such luck, suggestions have been to use a type of air filter to cover it, or a rubber bag something like a shower cap, or an actual box built around it to stop the splashes of mud. it seems clean water isn't that bad for it; it's mud. once it gets in the bushes the alt. cans.
'99 Rodeo V6 4x4 w/ 8" lift, 33" TrXus MT
4.77, Aussie Locked rear, 8500lb winch, custom rack, custom winch bumper, ProComp lights, 230,000km
http://www.cardomain.com/ride/2231794
Re: Let's talk about deep water [Re: rodeoredd] #734126 06/30/06 04:13 PM
Bigpoppax2 Offline
There are two types of snorkels that can fit. The type I got the Safari Snorkel that I got through Matt for about 300 bucks. Part number HS100HF
It's not too bad of an install. The template won't work because it's not made for our trucks. The only modification necessary to make it fit is you have to cut the inner fender section and take some material out of it because it's too long and hits the back fo the turn signal.
Ok, the other one that will work you can get from TJM. But I think it's really high like $600+
http://www.tjmproducts.com.au/brochures/rodeo.pdf
You need to paste this into the browser. Scroll down to the red pickup, there are two different models. They are not cheap.
Joe
Re: Let's talk about deep water [Re: Bigpoppax2] #734127 06/30/06 05:02 PM
onebadtrooper Offline
Yeah we were quoted like $650 for the tjm shipped by air.
It would have been like $200 cheaper for them to ship it on a boat, but they said that could take 6 months <img src="/forums/images/graemlins/zombie.gif" alt="" />.
My brother still might get it though.
The reason I got my snorkel was that I went through deep water a few times an injested some water, and scared the crap out of me.
I've had my engine submerged quite a bit, my altnator has been fine so far. But I've only gone through clean water, not muddy dirty water.
The only problems I have when water fording are my distributer(sp?) Its not 100% sealed, and my motor kind of studders when it gets wet.
The other thing is my exhaust, I've put a custom bigger than factory exhaust, and my little motor doesn't have enough back pressure to keep water out.
So I've got to figure those few things out before I go in deep water again.
But I'm impressed with my trooper so far with the snorkel, I've had my trooper floating with the engine still running.
I did have my smog pump seize up on me though. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Let's talk about deep water [Re: Bigpoppax2] #734128 06/30/06 05:38 PM
TrailMystic Offline OP
The TJM snorkel said it was a Pathfinder. Do they make one for the Rodeo, or do you have to adapt?
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: Let's talk about deep water [Re: TrailMystic] #734129 06/30/06 05:50 PM
The tjm is made for a holden rodeo. Its for a R9 v6 holden rodeo. You can call tjm and get a exact quote.
here are a few pics.
LINK
Re: Let's talk about deep water [Re: onebadtrooper] #734130 07/01/06 05:35 AM
icu_runnin Offline
If you want to see deep, i have one of ONEBADTROOPER in 3+ feet of water. I will host it real quick.
92 Galant VR4 #501/1k - Turbo, All Wheel Drive with 4 wheel steering - Money eatin toy
89 Isuzu I-Mark RS sings to 7800 RPM - Daily Driver
Re: Let's talk about deep water [Re: TrailMystic] #734131 07/01/06 05:41 AM
icu_runnin Offline
Re: Let's talk about deep water [Re: TrailMystic] #734132 07/03/06 03:54 AM
jsanford Offline
could you put a container around the alternator and pressurize it with an air source? it would keep air flowing (though limited) and water out. it wouldn't be permanent, just slipped on prior to major water crossings.
i was just wondering if that was possible or feasible. i do well to change my own oil so i possess no mechanical skills or ablity but was just curious about the idea.
joel
joel s.
'01 trooper (the misses') and 265/75/16/C dueler AT
'95 f150 4x4, leveling coils and 32 inch maxxiss buckshots
Re: Let's talk about deep water [Re: TrailMystic] #734133 07/04/06 01:14 AM
I kinda like the tjm snorkel. Maybe I'll order one now and get it by Christmas (by boat).
I have noticed one new sound since I did the deep water. It's kinda of a singing sound (not too loud) and it does it more at higher rpm. Hopefully I haven't messed up the alternator bearings.
Pete
Re: Let's talk about deep water [Re: TrailMystic] #734134 07/04/06 01:22 AM
mlclark Offline
Isuzu Moderator
Hope harder. <img src="/forums/images/graemlins/smile.gif" alt="" /> That is pretty much the siren song of dying alt bearing/bushings.
Michael
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6443 MB (Peak: 0.7664 MB) Data Comp: Off Server Time: 2026-06-17 11:40:59 UTC
