Broken Transmission? #734140 06/28/06 04:19 PM
TATER Offline OP
84 4runner w/ 5speed and dual cases.
I installed dual cases on a used/unknown transmission. Rear t-case was a junkyard find also.
The problem.........after everything was installed, the truck drove 60 feet and POW, it stopped going anywhere. Monkeyed the shifters and it climbed onto a trailer. I get to where I'm going and try to back the Runner of the trailer, and POW, same noise. No matter how I fool w/ shifters, the truck wont move.
Driveshafts wont turn at all. All shifters feel like they engage properly. I could put trans in gear, let out clutch while shifting t-cases and feel/hear gears engaging.
I yanked the driveline combo out and have split the trans from the t-cases. I also split the adapter off of the cases.
Shift rails and forks on cases look good. Coupler from adapter looks good. I havent dissasembled the rear case.
I can shift the trans into any gear and get movement from output shaft. Same w/ t-cases. Everything feels good using my hands to rotate input/output shafts.
I dont believe the clutch has shattered. I will pull the pressure plate off this week and see.
The questions...........can a transmission have a broken shaft yet still feel OK by hand? Can a complete t-case have the same issue? What should I look for?
Re: Broken Transmission? [Re: TATER] #734141 06/28/06 07:49 PM
Jeffstoyo Offline
Try contacting Marlin at Marlincrawler.com. He knows these tranny and tcases very well.
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: Broken Transmission? [Re: Jeffstoyo] #734142 07/05/06 04:24 AM
TATER Offline OP
Stripped rear outputb on t-case. Fixed now.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5953 MB (Peak: 0.6492 MB) Data Comp: Off Server Time: 2026-06-07 10:13:01 UTC
