Does this sound familiar to anyone? #734397 06/29/06 02:49 PM
wademan Offline OP
I'm experiencing this strange thing when I travel over rough/bumpy roads, etc. It's tough to describe, but it's kind of like the steering is briefly disconnected. Like there's no feedback coming through the wheel -- so I don't feel in control. Can't tell if it's some bad suspension part or if something is broken. It's a little scary at higher speeds.
If anyone can give me a clue -- I'm guessing I should get this checked out.
02 Taco 4x4, V6, TRD
Re: Does this sound familiar to anyone? [Re: wademan] #734398 06/30/06 01:15 AM
john_luttrell Offline
slow down on bumpy roads; sounds like you are going faster over the bumps than the shocks can control the wheel hop.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: Does this sound familiar to anyone? [Re: john_luttrell] #734399 06/30/06 05:12 AM
DentedTacoma Offline
Sometimes the wheel hop can just be bad shocks though. I just replaced some old rear shocks and put in new ones and it was like night and day. I hadn't changed them since getting the truck last summer so I thought that was how it rode but now it is soooooooo much better. I sat check your suspension components I think I get what you mean.
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: Does this sound familiar to anyone? [Re: DentedTacoma] #734400 06/30/06 06:22 AM
52degrees Offline
That feeling you get is from one or both of your front tires not touching the ground. Slow down or get better shocks or both.
KG6VNX
Re: Does this sound familiar to anyone? [Re: 52degrees] #734401 06/30/06 08:02 PM
wademan Offline OP
Thanks for the responses. That makes sense to me.
Since I'm not driving any differently than I usually do, I guess my suspension needs a little attention.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6043 MB (Peak: 0.6684 MB) Data Comp: Off Server Time: 2026-05-29 18:15:45 UTC
