Rebuild lube on bearing inserts #734633 06/30/06 05:15 PM
This is my first engine rebuild. Is it OK to lube up the back of the bearing inserts on the crank and the connecting rods? Someone mentioned an increased chance the bearings will spin out. I need a consensus.
Thanks,
Dean
Re: Rebuild lube on bearing inserts #734634 06/30/06 05:43 PM
Esquire812 Offline
You only lube the front face of the bearings (facing the crankshaft) period. The mounting surfaces of the block, main caps, rods and rod caps should be clean and dry. Apply enough assembly lube to protect the rotating assembly but dont go overboard so that its spooging out the sides in great quantity when torquing down the caps.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Rebuild lube on bearing inserts [Re: Esquire812] #734635 06/30/06 06:28 PM
Crap! <img src="/forums/images/graemlins/angry.gif" alt="" /> Fortunatly I only got as far as the crank shaft and #1 piston. Still...
Thanks for the help,
Dean
Re: Rebuild lube on bearing inserts #734636 06/30/06 08:28 PM
kyle-22r Offline
really isn't any point in putting the goop on the back sides, they don't move anyway. i do use a gob of grease on the back side of the thrust washers to hold them in place while i install the crank and 3rd main cap though.
and i'm opposite to darin's technique when it comes to assembly lube -- i slather that stuff on there! i'm pretty fond of the federal mogul green KY type stuff that comes in the little bottle myself.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Rebuild lube on bearing inserts [Re: kyle-22r] #734637 07/04/06 02:04 AM
on the subject....does anyone have any good tecniques on getting the rod caps off....i'mm having a hellacious time with #3
Re: Rebuild lube on bearing inserts #734638 07/04/06 02:37 AM
DirtCheap Offline
To remove the rod caps lightly tap on the rod bolt to force the rod away from the rod journal. I. leave the nut on while doing this so the rod bolt won't scratch the crankshaft.
1989 Toyota SR5 DLX SB
1995 Toy DX XTRA Cab 4x4
1989 Dodge Raider 3.0 V6, 5 spd, Michelin LTX series, bouncey seat
1988 Dodge Raider A/T w/Offroad Package
1959 Corvette
1977 Z28
1979 Honda CBX 1000 6 cyl
Re: Rebuild lube on bearing inserts [Re: DirtCheap] #734639 07/04/06 05:54 AM
wow....thanks man...i can't believe i havent thought of that.... <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Rebuild lube on bearing inserts #734640 07/04/06 02:13 PM
yea use the wooden part of the handle if you have a rubber mallet and use plenty of lube ,if it oozes out thats just extra to get slung around during starting.DO NOT put any on the backsides ,like was said before clean and dry .
Re: Rebuild lube on bearing inserts #734641 07/04/06 02:35 PM
engnbldr Offline
>>>*I have this old service manual, it has engine models out of the 20's and 40's.
There is a line in there that says to completely dip the entire bearing shell in oil before installing to make sure that it slips in without "marring".
I always got a kick out of that.
Of course there is no logical reason to oil the backside of a bearing shell, but it also would cause no harm, excess would just squeeze out.
On the dipper style bearings which are poured and fitted, it states to use a "suitable tool such as a sharp knife" to scrape the excess material until it can be "slid sideways freely by hand after tightening the retention nut."
I did exactly that with my pocket knife when redoing the rods on my Dad's 1937 Chevy 10 ton truck, and old 216.5 Cubic inch inline six.
The lube we used was axle grease....*LOL**....*EB
*Beats the he** outa me!....*LOL**...
Re: Rebuild lube on bearing inserts [Re: engnbldr] #734642 07/04/06 03:13 PM
OOP'S Offline
That was one way I was taught, the other way was to "fit" the rod caps, in other words "mill" the rod cap-mating surface on a flat surface and a sheet of "crocus cloth". One rebuild we did not have any assembly lube so we went into the kitchen and grabbed the Crisco. Seemed to work, the engine stayed together for many miles!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Hey EB did you ever use a piece of leather for a rod/main bearing. My Grandpa did on his Model A!!!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6342 MB (Peak: 0.7574 MB) Data Comp: Off Server Time: 2026-11-16 01:19:56 UTC
