92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes #734804 07/01/06 06:44 PM
Airtight Offline OP
Hello, I just pulled the codes off my 92 trooper 3.2 SOHC, and I got a code 14(Coolant Temperature Sensor Circuit) and a code 24( Vehicle Speed Sensor (VSS) circuit). I already assumed I needed a new vehicle speed sensor, because my speedometer works intermittently. The reason I checked the codes is because my engine idles vey high when I first start it up, whether it is cold or hot. Then after about 5 minutes, the check engine light comes on, and the engine settles down to a normal idle. I was just wondering if anyone could tell me what to check, or has had this problem. I recall on my '88 Troop the coolant temp sensor played a part in the idle speed if it got too hot or something. Any help would be appreciated.
Re: 92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes [Re: Airtight] #734805 07/01/06 06:56 PM
CPOM Offline
The VSS on the 1st gens was in guage cluster and signaled by the speedometer cable, not sure if the 92 troop is like that also. If your cable is broken the VSS will not work. Disregard this if you have the electric VSS.
Maybe the CLT sensor is bad? You could at the very least check the connection for corrosion and its on tight.
CHRIS
98 Amigo, 92 Pup
Re: 92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes [Re: CPOM] #734806 07/02/06 05:22 AM
Airtight Offline OP
I went out and looked for the coolant temp sensor, I have a spare one I could put in if I could find the thing. Anyone know where it is? Thanks CPOM, I have an electric vss, no cable.
Re: 92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes [Re: Airtight] #734807 07/02/06 07:42 PM
CPOM Offline
Should be on the top of the engine somewhere in the intake manifold, check around the coolant exit port /thermostat housing.
CHRIS
98 Amigo, 92 Pup
Re: 92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes [Re: Airtight] #734808 07/03/06 02:27 AM
JLEMOND Offline
THE COOLANT TEMP SENSOR IS ON THE WTR CROSSOVER PIPE BEHIND THE ENG ,THE EASIEST WAY TO ACCESS IT IS TO LOOSEN THE TRANS MOUNT BOLTS AND JACK UP THE BACK END OF THE TRANS ,THIS WILL TILT THE ENG UP AND FORWARD IN THE BACK AND MAKE IT MUCH EASIER TO REACH JERRY
Re: 92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes [Re: JLEMOND] #734809 07/03/06 04:52 AM
Airtight Offline OP
OK, thanks everyone. Thanks Jerry, for the tips. I'll let you guys know how it goes.
Re: 92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes [Re: Airtight] #734810 07/05/06 06:09 AM
Airtight Offline OP
One more question, is there anything else that could go bad with that circuit other than replacing the sensor itself? And do I have to remove the driveshaft or loosen any other engine mounts to get it to tilt forward by jacking up the tranny? Thanks again.
Re: 92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes [Re: Airtight] #734811 07/06/06 03:35 AM
JLEMOND Offline
THE SENSOR HAS A BIG EFFECT ON COLD START AND WARM UP AND HOT IDEL ALLSO, NO JUST UNBLOT THE TWO LOWER TRANS BOLTS OR RATHER THE NUTS IN THE CROSSMEMBER AND RAISE THE TRANS ABOUT 2-2/1/2 IN JERRY
Re: 92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes [Re: JLEMOND] #734812 07/08/06 07:27 PM
Airtight Offline OP
Ok, I did it this morning. Thank you to everyone, especially Jerry for the how-to. Everything went well, and that fixed the problem. You guys rock.
Re: 92 Troop 3.2 SOHC coolant temp sens. circuit & VSS codes [Re: Airtight] #734813 07/09/06 07:11 AM
trooperbc Offline
thanks for the followup.
anything you ran into that might help me do mine?
i'm having a little trouble visualizing the jerry lemond tip. . .is it as simple as "advertised"?
tia
btw, what about the other code?
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6381 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-06-21 18:54:53 UTC
