oil leaks #735017 07/03/06 12:41 AM
8
89liftedrs Offline OP
Well, been working on my rs for almost 2 months now, trying to make her right, in prep for a drive to Central America. Have rebuilt the truck from the crank up, with slight aftermarket mods(cam, exhaust, had to bore .20 over) Now I have oil leaks under pressure as well as no pressure(seems to be form the cast aluminum oil pan under pressure right blow the timing cover) on the front of the engine. And I think from the rear main seal or oil gallery plug as well with no pressure & with pressure.. or both. Dumb q I know but any suggestions? She runs good, And will be taking her on her first little test run(40-50 miles tomorrow) Any danger comments. Hoping she will heat up and stop but that is a serious hope that I know won't come true. Just hate to believ that I gotta pull the engine for a 3RD time to make her right. Sorta venting on this end but would appreciate any suggestions. I'll keep it short from now on. Thanks ahead of time, -Noel-
Re: oil leaks [Re: 89liftedrs] #735018 07/03/06 01:58 AM
mlclark Offline
Isuzu Moderator
Any of those places you mentioned could be leaking. You will have to clean it off and take a look.
Where did you source your galley plugs from? Isuzu? If not, they may not be sized correctly, as those are metric sized holes. SAE will come close, but maybe not close enough.
Good Luck,
Michael
Re: oil leaks [Re: 89liftedrs] #735019 07/04/06 04:41 AM
9
94redrodeo Offline
89 lifted rs what color is you RS
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5941 MB (Peak: 0.6480 MB) Data Comp: Off Server Time: 2026-06-22 07:30:32 UTC
