1999 4runner coolant leak. possible headgasket? #735355 07/04/06 05:39 PM
vrooooom Offline OP
I have a 1999 4runner coolant leak. I get a little puddle on the driveway every morning. It's not coming from the radiator hoses. Could it be the headgasket?
Is there a recall on the headgasket for a 1999 4 runner? The 4runner has about 130k miles.
Re: 1999 4runner coolant leak. possible headgasket? [Re: vrooooom] #735356 07/05/06 06:52 PM
No there is no head gasket recall for 1999. The ended it in 1996.
The leak you have is probably water pump if you still have original.
Re: 1999 4runner coolant leak. possible headgasket? #735357 07/05/06 10:57 PM
vrooooom Offline OP
The leak is coming from the back of the engine. Could it be the heater hoses?
Re: 1999 4runner coolant leak. possible headgasket? [Re: vrooooom] #735358 07/11/06 05:09 PM
code33 Offline
Yes, it could be a heater hose or a small coolant line. The best way to check it is to pressure test the system. You'll probably be able to locate the leak this way.
FWIW, there has NEVER been a recall for the head gasket. Toyota had a Special Service Campaign (SSP V06) for head gaskets. This was a special warranty; recalls are for safety issues.
Re: 1999 4runner coolant leak. possible headgasket? #735359 07/13/06 03:02 AM
kewlynx Offline
HG recall was for the 3.0 and 14K of the first 3.4 engines.
I second the pressure check.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6030 MB (Peak: 0.6635 MB) Data Comp: Off Server Time: 2026-06-25 01:19:16 UTC
