Trans Problems #735783 07/06/06 06:41 AM
A
AUSSiE78 Offline OP
Hi all....
I think I am about to have a large problem with my Manual transmission <img src="/forums/images/graemlins/confused.gif" alt="" /> Hope not, but here goes.... Selecting gears is rather hard to do, especially first when starting out, I need to push rather hard to get it to go into gears, and it kinda gives a little "click/pop" when it finally engages. Starting out in first is a little chatterry (sort of surges, can feel the truck moving forward - like when you slow down and have warped disc brakes - hope that makes sense) Starting in second is a little bit worse, I can feel it surging more. Also when the clutch pedal is released all the way to the top it makes a squeeky squeek <img src="/forums/images/graemlins/drunk.gif" alt="" /> noise, like a spring is rubbing on something. does it with truck running or not, and can feel through the pedal. Sounds like it's coming from under the truck - right around where the tranny is <img src="/forums/images/graemlins/smile.gif" alt="" />
Last week I took my kids to a local water/mud hole and ran through that a few times until the truck started running like crap and the clutch started to feel a little spongy <img src="/forums/images/graemlins/zombie.gif" alt="" /> What could be the problem? Water in the trans? Water not high enough for submerging even the axles, but splash it did!
Sorry for the longggg post but i'm tired and not sure if I made any sense. Thanks all,
AUSSiE
'88 4Runner
3.0, mod'd intake, dynomax exhaust, everything else stock.
Life will always go on....
Re: Trans Problems [Re: AUSSiE78] #735784 07/06/06 08:58 AM
Ganoid Offline
Sounds more like a clutch issue to me?
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: Trans Problems [Re: Ganoid] #735785 07/06/06 02:46 PM
Staceman Offline
Sounds like clutch to me too. Check freeplay, fluid level, and bleed if necessary.
Re: Trans Problems [Re: Staceman] #735786 07/07/06 03:10 AM
A
AUSSiE78 Offline OP
thanks guys, I will check the clutch free play and stuff... maybe tear out the clutch and inspect it too..... nah, wait til it craters! <img src="/forums/images/graemlins/evil.gif" alt="" />
AUSSiE
'88 4Runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6021 MB (Peak: 0.6585 MB) Data Comp: Off Server Time: 2026-06-17 04:12:56 UTC
