Re: Sas guys death wobble cure? [Re: Sammy] #735973 07/09/06 08:12 PM
E
Eric Upchurch Offline
Check your shackle bolts, they can come loose and give very bad wooble. It happened to my roomates sas 4runner and my trooper. I run nylock nuts with locktite now. Also check your bushings, are they new? hows your tire pressure? check all the basic stuff like that first and see if you see any improvements then check your caster.
New rig: 89 trooper RS toyota axles with 5.29s, 35x15.5x15 swamper SXs
my Pics: http://community.webshots.com/album/124372714fTyMKI
Wrire up:http://personal.ecu.edu/emu0416/
Re: Sas guys death wobble cure? [Re: Eric Upchurch] #735974 07/09/06 08:21 PM
88SuperTrooper Offline
Just In case, you dont after market wheels on it do you? If so are the lug nuts the right fit for that style of wheel. and just out of curiosity are the wheels centered up right on the hub and those little clips that hold the brake rotors and sometimes brake drums have when they come out of the factory. IF you do not remove those they will cause Vibrations and sometimes the wheel(s) to come off. I work at a tire shop and have pretty much seen it all, just throwing some ideas out to see if it helps. maybe you also have a bent wheel or 2? It doesnt take much bend to cause a wicked vibration. like Eric says stay basic then you can really narrow it down. Robbie
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: Sas guys death wobble cure? [Re: 88SuperTrooper] #735975 07/10/06 05:21 AM
9
94redrodeo Offline OP
We adjusted the toe was way too much in since adjusting it hasn't done it yet. But now it has a blow head gasket. <img src="/forums/images/graemlins/angry.gif" alt="" />
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: Sas guys death wobble cure? [Re: 94redrodeo] #735976 07/10/06 11:21 AM
Sammy Offline
You have to be kidding me!!! Not much you can do to predict that, but I feel like crap. What happened??? Let me know what I can do to help.
Sammy
95.5 Rodeo, automatic, 3.2 SOHC, D44 front and rear, 4.88's, 33" muds
Re: Sas guys death wobble cure? [Re: 94redrodeo] #735977 07/10/06 07:05 PM
kobyhud Offline
Yeah I had bad death wobble in the beginning... TOE is a HUGE cause for death wobble, Especially too toe in.
Hydro assist can eliminate pretty much all death wobble... <img src="/forums/images/graemlins/wink.gif" alt="" />
95 Rodeo LS, Auto, SAS, , 60 front, 14 bolt rear. 5.13 r&p, Hydro-Assist, teras..
http://www.pieceofhud.com/gallery
Re: Sas guys death wobble cure? [Re: kobyhud] #735978 07/12/06 08:58 PM
94rodeo Offline
On my rig, the death wobble was from the pan hard/track bar, the first set up mount on the frame would actually flex side to side and the whole truck would slam side to side about 6 inches in each direction to a point that I had to stop the truck and fast or it would keep going. This is actual death wobble, called such because if kept going the truck would literally shift side to side enough that it would either roll or break parts. This has since been fixed by beefing up the mount. If you are getting the wobble on your leaf spring set up, try what has been mentioned, especially the shackle bolts, if there is slop in there, it will cause the vehicle to move side to side a little.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6180 MB (Peak: 0.7043 MB) Data Comp: Off Server Time: 2026-05-29 18:57:48 UTC
