Page 2 of 3 1 2 3
Re: Open to Suggestions - Oil Pan Rusted Thru and Leaking [Re: Lennyburger] #736133 07/15/06 10:46 AM
Calappoyas Offline
There'a the ol' timer's copper penny trick... melt a penny on a hot piece of shaft and lift up to patch hole. <img src="/forums/images/graemlins/notooth.gif" alt="" />
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
sportage lift [Re: Calappoyas] #736134 05/23/07 08:26 PM
Jgaudet Offline
where can i find a suspension lift and a body lift for my 02 sportage???
Re: sportage lift [Re: Jgaudet] #736135 05/24/07 12:26 AM
DEFBOY35 Offline
do a search or a quick look through many of the recent posts and you will find your answer.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: Open to Suggestions - Oil Pan Rusted Thru and Leaking [Re: Axe Man] #736136 05/26/07 06:31 AM
bombardj1 Offline
how about this degrease and wire brush it down instead of JB weld ( which can get brital) how about glass or cloth mesh and epoxy, I would put thin coats of epoxy let dry sand then a other thin coat and so on. steel bondo and mesh might work also. John
Re: Open to Suggestions - Oil Pan Rusted Thru and Leaking [Re: Axe Man] #736137 05/28/07 02:01 AM
Iron Offline
Never used JB weld, but at work we use somthing simular called Def-Con
One time while doing an overhaul on a large V-12 White Superior engine (7500 Cubic Inch) Someone who will remain nameless grinded a little to much of the block away while cutting out the lower cylinder liner. we were doing a liner fit. We used Def-Con to fill the gash, when it was set we machined the lower clyinder and fit a new liner. The engine is running fine.
Long story short, if this stuff can hold together under the internal pressure of a large engine that runs non stop for anywhere from 2 to 10 years under load all the time, then I think it should hold a small patch on a sporty's oil pan!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: Open to Suggestions - Oil Pan Rusted Thru and Leaking [Re: Iron] #736138 05/31/07 04:08 AM
Axe Man Offline OP
Kia Moderator Emeritus
Appreciate the recent thoughts. This thread dates back to last July. It got revived with the question about lifts (???).
Anyway, I sold the Sportage last September so it's a moot point. With the leaking oil pan and the new owner knew exactly what he was facing. Last I heard my old truck is still running and they STILL have not fixed the leak in the pan. I'm afraid one of these days it's going to pop and they'll lose all the oil and ruin the engine. But I guess it's not my problem.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Open to Suggestions - Oil Pan Rusted Thru and Leaking [Re: Axe Man] #736139 05/31/07 06:30 AM
Hydra747 Offline
Surprised that it took you that long to respond to this AXE! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Open to Suggestions - Oil Pan Rusted Thru and Leaking [Re: Hydra747] #736140 05/31/07 06:46 AM
Axe Man Offline OP
I was responding to the posts made after 5/23 of this year.
Re: Open to Suggestions - Oil Pan Rusted Thru and Leaking [Re: Axe Man] #736141 05/31/07 06:50 AM
Hydra747 Offline
I know! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Open to Suggestions - Oil Pan Rusted Thru and Leaking [Re: Hydra747] #736142 06/01/07 08:32 PM
Cen_Tex_KIA Offline
Just my chime, but try it. I have a25 year old Yahama with the Crank Case held together by JB for 6 Years now.......and ther is now way your kia takes the vibration abuse this bike does, Offroad........and I fall off alot! <img src="/forums/images/graemlins/shiner.gif" alt="" />
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6440 MB (Peak: 0.7644 MB) Data Comp: Off Server Time: 2026-05-25 18:56:47 UTC
