Bad Fuel Injectors? #736157 07/08/06 07:52 PM
Rodeo Clown Offline OP
Stats:
1992 Rodeo
3.1L V6
Story:
I was driving my Dad's Rodeo and it was working just fine. Then just as I was pulling into a parking lot it died and wouldn't restart. We checked the fuel filter and pump. Found the pump was dead and replaced it with the filter.
It still wouldn't start so we checked to see if the injectors were getting power(suspect due to small fire while using starting fluid. <img src="/forums/images/graemlins/shiner.gif" alt="" />) and they were. So we think it is the injectors themselves.
How would we go about testing them to see if they work or not? Any other ideas?
Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
Re: Bad Fuel Injectors? [Re: Rodeo Clown] #736158 07/09/06 05:01 PM
N
NotSoSimple Offline
Take them out and take them to an injection shop. The other option is to somehow find an injector tester and note the spray pattern.
'90 Trooper - 2.6L 5-Speed - 1" BL - Custom Roof Rack+2x55watt ProComp - Herculined Interior - Pace Setter Header - Dynomax Super Turbo - K&N - ProComp ES3000 Shocks - Optima Red - MSD 6A - 31" Kumho Mudders - Black Rock Crawlers
Re: Bad Fuel Injectors? [Re: Rodeo Clown] #736159 07/09/06 08:06 PM
mlclark Offline
Isuzu Moderator
Are the injectors spraying fuel? If they have power, they should be spraying fuel, even if it is a really poor pattern.
Michael
Re: Bad Fuel Injectors? [Re: mlclark] #736160 07/10/06 05:56 AM
Nope. No fuel goes through them. We get it clear up to them, but not through.
When we checked them they both had about 12 volts going to them.
Re: Bad Fuel Injectors? [Re: Rodeo Clown] #736161 07/10/06 04:10 PM
JLEMOND Offline
DO YOU HAVE 12 VOLTS OR CLOSE TO IT ON BOTH SIDES OF EACH INJ, IF SO YOUR PROBLEM IS IN THE WIRING TO THE ECM OR THE ECM ITSELF ,WITH THE ENG SPINNING OVER YOU SHOULD HAVE 12 VOLTS ON ONE PIN OF THE INJ ONLY , THE OTHER PIN IS INTERMITTENTLY GROUNDED BY THE SPARK CONTROL MODULE , THIS IS WHAT CAUSES THE INJ TO PULSE ON AND OFF , IF YOU ARE SURE YOU HAVE FUEL PRESSURE , TAKE A JUMPER WIRE AND MOMENTARILY GROUND THE BLU OR THE GRN WIRE AT THE INJ CONNECTOR , JUST A CLICK ,CLICK AND SEE IF THE INJ SQUIRTS FUEL IF IT DOES YOU HAVE A WIRING PROB, OR SPARK CONTROL MODULE OR THE ECM , DO NOT TOUCH THE BLK/BLU WIRES TO GROUND THOSE ARE HOT ALL THE TIME THE KEY IS ON , THE INJ ARE GROUNDED BY THE ACTION OF THE ECM AND THE SPARK CONTROL MODULE , IF YOU ARE A LITTLE SCARED ABOUT GROUNDING THE INJ, JUST UNPLUG THE SPARK CONTROL MODULE AND THEN DO THE GROUNDING TEST, NOTHING CAN BE HURT THIS WAY AND YOU CAN TRIGGER THE INJ TO SEE IF IN FACT THEY ARE WORKING , JERRY
Re: Bad Fuel Injectors? [Re: JLEMOND] #736162 07/12/06 05:41 AM
Well, I shorted the injectors and all I got where sparks. I made sure that I was grounding the correct side and they were disconnected from the plugs. So I would assume that the injectors are bad then. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Bad Fuel Injectors? [Re: Rodeo Clown] #736163 07/13/06 02:06 AM
JLEMOND Offline
if the inj didnot make any type of clicking sound , it sounds like the inj may be shorted , with 12 volts applid to one terminal and the other grounded momentarily , the inj should make a click sound, just aparking , sounds like a defecttive inj JERRY
Re: Bad Fuel Injectors? [Re: JLEMOND] #736164 07/13/06 02:47 AM
Alright. That's kind of what I thought. I'll let my dad know. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6219 MB (Peak: 0.7008 MB) Data Comp: Off Server Time: 2026-06-07 05:00:27 UTC
