Fuel Line Question #736245 07/09/06 03:41 AM
9
92daily Offline OP
So during the tear down, while trying to unhook the fuel line (pre-fuel filter) I broke the corroded line. Short of going to the dealer and buying a new fuel line, is there a way I can maybe use a rubber hose and a clamp or anything like that? If I can drop the front end tomorrow to get the damn oil pan back on (cant jack the motor up enough with the head on) and get this fuel line fixed I'll be ready to roll. So, can a hose and hose clamp work as a temporary solution?
I'm between toyotas right now... 3rd Gen 4-runner soon.
Re: Fuel Line Question [Re: 92daily] #736246 07/09/06 04:02 AM
5
5150 Offline
Yes I have had the rubber hose quick fix on m '93 for about two months now. I have driven the truck the same way as always.....hard, and have not had any problems yet. I do plan on spending the 45 bucks canadian and buying the new hard line. This resulted from a fuel filter change.
Re: Fuel Line Question [Re: 5150] #736247 07/10/06 12:13 AM
9
92daily Offline OP
So i picked up some rubber fuel line to do a quick fix. The line I got is rated to 50psi, I know the EFI system doesnt run that high pressure. Just out of curiosity though, what kind of pressure do our EFI systems run?
Re: Fuel Line Question [Re: 92daily] #736248 07/10/06 12:17 AM
4Crawler Offline
Pressure regulator keeps it in the 30-40 psi range.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6038 MB (Peak: 0.6596 MB) Data Comp: Off Server Time: 2026-06-06 22:03:00 UTC
