Page 4 of 5 1 2 3 4 5
Re: My Build [Re: valleycat] #736334 08/10/06 02:38 AM
DentedTacoma Offline
There is always more money to spend with a 4x4. I usually think that I will be all set with my next purchase and not get anything for awhile but then another thing comes to mind. The bottomless pit of spending that is a truck (in my case).
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: My Build [Re: DentedTacoma] #736335 08/10/06 04:32 PM
JeePete Offline
I'm surprised to see you plan on an AW-4 on a ground up off road build. It's a great Cherokee transmission, but not very heavy duty. I think one in a YJ or CJ would be cool for mild use but I would look for something a litte less electronic and more stout for a built up off road rig. But that's just me.. Good luck with your project, it sounds like fun. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: My Build [Re: JeePete] #736336 08/19/06 08:46 PM
Tikitgvr Offline OP
Well got the body off of the old frame today with the assistance of smitty and his straps.....
Also got the 9" completely ground down no brackets left...
And thought I would take a pic of my puppy chewing on my lug nuts on my carrier....
Re: My Build [Re: Tikitgvr] #736337 08/19/06 09:24 PM
Where is the body going? Or was the trailer the easiest way to move it?
Re: My Build #736338 08/19/06 09:33 PM
Tikitgvr Offline OP
easiest way to move it...It will sit on there until I am ready to put it on the new frame...I am going to do all my axle work and mount them, the motor, tranny and tcase before I put it back on....that way its hella easier...
Re: My Build [Re: Tikitgvr] #736339 08/26/06 02:33 AM
Tikitgvr Offline OP
Well got my donor motor pulled today, new frame moved into shop, and motor set on it. Found out that an XJ motor is set up alot different than a TJ. I have to get a different alternator bracket because it hits the frame as you can see in the pic.
Re: My Build [Re: Tikitgvr] #736340 08/26/06 04:20 AM
BigJim Offline
Where do you find the time to take photos? I am always either too greasy or sound asleep!
Re: My Build [Re: BigJim] #736341 08/26/06 12:14 PM
Tikitgvr Offline OP
Yeah I hear ya... I do it as soon as I get washed up and before I sit down.....
Re: My Build [Re: Tikitgvr] #736342 08/26/06 03:46 PM
Are you going to convert it back to the TJ style manual fan, or are you going electric?
Re: My Build #736343 08/26/06 05:03 PM
Tikitgvr Offline OP
I was thinking of both....I was thinking of mounting an electric fan backwards on the front side...so that it is pushing air through and then also sucking it through....
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6389 MB (Peak: 0.7621 MB) Data Comp: Off Server Time: 2026-07-17 01:11:20 UTC
