gas in oil? #736606 07/10/06 05:26 PM
bigjeep1980 Offline OP
Is it possible when a carburator fails... leaking gas... for some to end up in the oil? Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: gas in oil? [Re: bigjeep1980] #736607 07/10/06 08:23 PM
john_luttrell Offline
Yes it is possible, but another possibility is the mechanical fuel pump has failed allowing fuel to enter the crank case.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: gas in oil? [Re: john_luttrell] #736608 07/10/06 11:36 PM
BigJim Offline
What John said... Look to the fuel pump first. The carb has so little gas in it that it is hard to conceive you would detect gasoline in the oil from one.
WHY are you suspecious of gas in the oil?
Re: gas in oil? [Re: BigJim] #736609 07/11/06 01:13 PM
Thanks guys...I appreciate it! <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6006 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-10-21 20:41:57 UTC
