gas in oil?
#736606
07/10/06 05:26 PM
Is it possible when a carburator fails... leaking gas... for some to end up in the oil? Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: gas in oil?
[Re: bigjeep1980]
#736607
07/10/06 08:23 PM
Yes it is possible, but another possibility is the mechanical fuel pump has failed allowing fuel to enter the crank case.
John Luttrell 2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: gas in oil?
[Re: john_luttrell]
#736608
07/10/06 11:36 PM
What John said... Look to the fuel pump first. The carb has so little gas in it that it is hard to conceive you would detect gasoline in the oil from one. WHY are you suspecious of gas in the oil? Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: gas in oil?
[Re: BigJim]
#736609
07/11/06 01:13 PM
Thanks guys...I appreciate it! <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6002 MB (Peak: 0.6553 MB) Data Comp: Off Server Time: 2026-10-21 20:41:48 UTCValid HTML 5 and Valid CSS
