Swing out tire carrier lock #736640 07/10/06 10:03 PM
anthony1 Offline OP
Do you guys have a lock on your tire carrier?
I was having lunch at a resturant and someone must have unlatched my tire carrier. I went through a few speed bumps then made a turn. Next thing I knew, the tire carrier swung open. Good thing I have a stop so it doesn't swing pass a certain point. Otherwise, it would hit the car coming the opposite direction. <img src="/forums/images/graemlins/angry.gif" alt="" />
Do you guys have locks on it or it's not a problem for you?
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Swing out tire carrier lock [Re: anthony1] #736641 07/11/06 03:56 PM
D-runner Offline
I have a lock on mine, not taking any chances here in Vegas. The lock is a Master Lock from the local RV store and has the hasp covered so it canÆt be cut. I also built mine so the tire blocks the key switch for the back window and ordered the wheel locks so they match my originals.
I also have a built in stop and an auto locking pin to lock the swing arm in the open position. The rest of the pics can be found here .
Adam W.
87 4Runner SR5 - 22RE w RV head & TRD Cam, LCE header, W56B-HD, 4" Stage II, 1.5" BJS, Rancho T-bars, F 5.29, R 5.29 ARB V6 FF w LC disks, 35" MT/R's
85 4Runner frame, 5" Marlin springs, 5:29 ARB HP front. Work in progress - Always!
Re: Swing out tire carrier lock [Re: D-runner] #736642 07/11/06 05:18 PM
anthony1 Offline OP
That is a nice setup.
Re: Swing out tire carrier lock [Re: D-runner] #736643 07/11/06 05:20 PM
AlaskaToy Offline
where didyou source the auto-locking pin? ANd, can you elaborate on your latch system too?
AJ
93 Toyota, dana 60, 14-bolt
Re: Swing out tire carrier lock [Re: AlaskaToy] #736644 07/11/06 07:13 PM
D-runner Offline
The latch is a locking pin/rewind pin from a BAK-12 aircraft arresting barrier that the USAF uses. You pull up on the T handle and the two balls in the other end are released and the pin can be pulled. You can find a pin like it at a tractor/farm supply store.
The auto-locking pin is home built. Starting with a ¥ö bolt. I welded a ring on top and drilled a small hole on the side of the shank. The bolt slips in and the spring is held with a cotter pin (on the bottom of the spring) so it is always trying to push the bolt down. As the swing-arm is opened and aligns with the hole in the bumper, the bolt drops down and locks the swing-arm open. Lift up on the bolt and swing the arm when closing.
Adam W.
Re: Swing out tire carrier lock [Re: D-runner] #736645 07/11/06 08:25 PM
Staceman Offline
The genius in this is the simplicity. All around, the best multi-use bumper I've ever seen.
Re: Swing out tire carrier lock [Re: Staceman] #736646 07/11/06 09:12 PM
A
allochris Offline
where do you buy the hinge?
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Swing out tire carrier lock [Re: allochris] #736647 07/11/06 10:54 PM
anthony1 Offline OP
www.rockstomper.com
I think there's another place..forgot where though..
Re: Swing out tire carrier lock [Re: anthony1] #736648 07/12/06 04:33 PM
D-runner Offline
4x4 Labs . If I had to do it all over again, I would have used their spindle. I know that some people have had problems with Rockstomper's spindles but I think that too much heat was applied when welding it to the bumpers. My father has one on his Jeep TJ for over 4 years now with a 33" spare, two gas cans and a rack and has had no problems yet.
Adam W.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6305 MB (Peak: 0.7360 MB) Data Comp: Off Server Time: 2026-07-16 08:50:08 UTC
