Tundra Factory Wheel on T100 #736806 07/11/06 02:47 PM
crain Offline OP
I haven't had good luck with getting aftermarket wheels to balance just right, so I was wondering if anyone has tried to mount this tundra wheel on their T100? I've always liked the look of this wheel. Just wondering if it would fit. Thanks in advance for your response. http://stores.implex.net/hubcapsUSA/itemDetails.cfm?item=1043&#
1996 T100 2WD (3.4L), IPT Valve Body Upgrade, JBA Headers, Downey Intake, URD Lightweight Crankshaft Pulley, PSC001-003 Fuel Calibrator, ADDCO Rear Anti-Sway Bar, Sway-Away 25mm Torsion Bars.
Re: Tundra Factory Wheel on T100 [Re: crain] #736807 07/11/06 03:19 PM
H2O_MAN Offline
Those will fit, but don't you think THESE would look better <img src="/forums/images/graemlins/kewl.gif" alt="" />
Locks, lugs, center caps boxed and ready to ship for less than those other rims. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Tundra Factory Wheel on T100 [Re: H2O_MAN] #736808 07/11/06 06:17 PM
crain Offline OP
Thanks H20_Man...your's are a good looking set too, but I really like the others above anything else I have seen.
Re: Tundra Factory Wheel on T100 [Re: crain] #736809 07/15/06 02:11 PM
cookiemech Offline
You can do a lot better on price for those wheels on eBay; I regularly see them go for $300 to $400 per set, in very nice condition.
1993 T100 4 x 4 longbed
2005 Tundra 4 x 4 longbed
Re: Tundra Factory Wheel on T100 [Re: crain] #736810 07/18/06 03:49 PM
Yes,they will fit. On a 4 wheel drive you will need atleast a 5/16 wheel spacer on the front wheels so the center caps on the rim will clear the dust cap on the hub. You might need to "massage" the hub dust cap with a hammer.Since yours is a 2 wheel drive they should fit no problem. web page
Re: Tundra Factory Wheel on T100 #736811 07/18/06 06:46 PM
crain Offline OP
Thanks much...Mollydog...yours is the look I am looking for. I have a set of 16X8 Weld Rims, but with all the after market rims I have tired, they just don't balance perfectly.
Re: Tundra Factory Wheel on T100 [Re: crain] #736812 09/11/06 02:55 PM
I am looking at buying some 2006 Tundra 16" rims. Does anyone know if they will fit my 1996 T100 4x4? I don't mind putting spacers in the front so the caps will fit. They are the aluminum alloys with P245-70R-16 tires. Thanks in Advance.
Re: Tundra Factory Wheel on T100 #736813 09/12/06 09:49 PM
wsquaredodie Offline
Watch out for the factory tundra wheels. There is an unofficial recall on them for pitting. Buddy has one and he complained to the dealer and they replaced them. Apparently there is something wrong with either the finish coating or the ally or both - salt city here as well...
trafdlo
Re: Tundra Factory Wheel on T100 [Re: wsquaredodie] #736814 09/13/06 02:29 AM
Thanks for the heads up. I might just stick with my Stock Steelies. If they get old I'll just paint em. No salt down here in Tx.
Re: Tundra Factory Wheel on T100 #736815 09/13/06 06:14 PM
Be glad to send you some......
trafdlo
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6283 MB (Peak: 0.7153 MB) Data Comp: Off Server Time: 2026-06-23 00:35:53 UTC
