Re: coolant---optimal mix? [Re: litnin] #736836 07/15/06 02:41 PM
ducktrooper Offline OP
Still a little confused...if I want to increase the "boiling point" capacity, will I best achieve with 60/40, coolant/water ratio or vice versa? Not too concerned about freezing temps here in Memphis. Thanks.
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Re: coolant---optimal mix? [Re: ducktrooper] #736837 07/15/06 03:03 PM
central Offline
If you want to increase the boiling point then have more antifreeze in there. But, think about why would you want to increase the boiling point. If that was your only goal you could put just sand in the radiator.
The key is heat transfer - out of the engine and out of the radiator. Pure water is pretty much THE best heat transfer fluid. Thus, in theory you should run pure water. In the real world you have to worry about corrosion, water pump seals, and freezing. Thus, the development of antifreeze with corrosion resistance and water pump lube chemicals.
Bottom line - antifreeze is good for some things. But too much is not your friend when it comes to keeping the vehicle cooled.
Re: coolant---optimal mix? [Re: Troopersphere] #736838 07/15/06 08:00 PM
Don_W Offline
How does your coffee taste now?
Don
1989 Trooper II 2.6L
222,222
Re: coolant---optimal mix? [Re: Don_W] #736839 07/16/06 03:29 PM
Thanks for your opinion. I was simply looking for some insight on mix ratios and seeking further clarification. I'm glad to know that sand and pure water also fall under the category of optimal mix. Coffee is quite strong I'd say.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6083 MB (Peak: 0.6802 MB) Data Comp: Off Server Time: 2026-11-19 05:35:48 UTC
