carbs #736873 07/11/06 09:15 PM
POLAK50 Offline OP
hey yall i just got my 1988montero from down southtexas from my folks and brought it up here and while i was down there. the thing has been siting for 5years, i found problems some which were the 1-the carb is messy and the lines are all mixed up. 2-something keeps draining the battery,dont know what maybe yall do? 3-the montero takes an eternity to start up! after say 15minutes the engine will start up but then die probably because of the carb issue. Im gonna get a new carb anyone have any <img src="/forums/images/graemlins/cheers.gif" alt="" />suggestions <img src="/forums/images/graemlins/patriot.gif" alt="" />? say holley,weber, maybe one on ebay?
88' Montero SWB 2.6L 5 speed, Got for free from my folks I couldnt stand the car I first drove just sit there and die.
Re: carbs [Re: POLAK50] #736874 07/11/06 10:04 PM
LRJ4x4 Offline
15 Minutes to start, well at least you found what was killing the battery...the starter <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
If it's been sitting 5 years the gas is bad. I would empty the tank by the drain plug. Replace the fuel filter, Fuel Pump and Carb. The fuel pump is diaphragm type and most likely dried out and cracked, ditto on the carb especially the depression chamber. I would just get a re-maned carb from FC products if you want to go OEM. Otherwise if your in a real mess and don't have emmissions you can get a Weber.
Once you get it started and warmed up you will want to change the oil ASAP. Then again, you will want to change every fluid in the entire truck. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: carbs [Re: LRJ4x4] #736875 07/11/06 10:46 PM
CapnCrunch Offline
Ditto on what he said.....change every fluid.
FC Products - CRY290 carb for 2.6L with manual transmission
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: carbs [Re: POLAK50] #736876 07/11/06 11:03 PM
POLAK50 Offline OP
thanks for the input the vehicle has about 220K its been through hell and back no huge problems before it became dormant for 5years. right now those are the major problems once i can get it idled i can check for leaks and check the gauges hopefully the rats didnt get to em first <img src="/forums/images/graemlins/lol.gif" alt="" /> ive changed the oil and ill get to the gas soon
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6026 MB (Peak: 0.6595 MB) Data Comp: Off Server Time: 2026-06-09 19:23:13 UTC
