O.B.A. Question. Do I need a tank?
#737129
07/13/06 05:10 AM
I'm in the process of gathering up the stuff to put onboard air in my YJ. My question is, Do I need a tank? Won't the compressor put out enough air to run my tools or air up my tires? I'm using a York air conditioning compressor for a pump. I already have a 3 gallon tank I could mount, but I want to see if it's necessary first.
Re: O.B.A. Question. Do I need a tank?
[Re: wyojeeper]
#737130
07/13/06 05:33 AM
Your going to want it as something to mount the pressure blow off and on/off switch as well as a buffer. The AC compressors are capable of 300 PSI or more, with just a line on it it will be hard to keep the pressure in a useable range. You can use some 3" pipe along the frame as a way to get a fitting to the rear and as a tank...
[Re: wyojeeper]
#737131
07/13/06 06:31 AM
a great number of the ranchers down here in thorn country use a pipe bumper for a tank. I had not seen a pipe along the frame but that is an idea worth looking into also. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#737132
07/13/06 06:46 AM
If it is ran with the frame it is protected from large boulders and such. If it is galvanized pipe, it should take a good beating...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5929 MB (Peak: 0.6521 MB) Data Comp: Off Server Time: 2026-06-13 10:45:04 UTCValid HTML 5 and Valid CSS
