Times are tough,down on my luck and yippy...my rear end is going out #737150 07/13/06 11:18 AM
W
Whatever Offline OP
Okay, so the rear end on my 1992 4x4 5-speed stnd cab stnd bed 22-RE is going out and is declining quickly. It feels like I'm driving against the wind all the time and it seems a little more windy every day...lol. I jacked up the rear and put it in gear and the rear end sounds like...well I don't know what it sounds like, but it doesn't sound good at all. It's also started to sling fluid everywhere, which is a lovely smell on the exhaust.I'm currently unemployed and low on the funds so I'm hoping some kind soul in SoCal can hook a guy up with a deal of some sorts. I hate feeling so desperate and being so broke, but I guess that's just how this crazy world works sometimes. If anybody can help me out, I would be forever greatful. Thanks.
Re: Times are tough,down on my luck and yippy...my rear end is going out [Re: Whatever] #737151 07/13/06 01:30 PM
4Crawler Offline
Likely the pinion flange is loose and/or the oil seal is leaking. You can replace the seal and tighten up the flange and that may help:
http://www.4crawler.com/4x4/CheapTricks/PinionSeal/index.html
Re: Times are tough,down on my luck and yippy...my rear end is going out [Re: Whatever] #737152 07/14/06 03:28 PM
salvo Offline
To bad ya didnt live closer...Im not comming to california to help ya <img src="/forums/images/graemlins/smile.gif" alt="" />. Been in the same situation yoou are ... got no money and broke truck. and it sucks
Re: Times are tough,down on my luck and yippy...my rear end is going out [Re: 4Crawler] #737153 07/16/06 08:47 PM
W
Whatever Offline OP
I know that I could replace that seal, however, there is more serious problems going on in there. When I start from a dead stop and make a turn (especially to the right) I get some slippage and a clunk or two when it catches. It even does it sometimes starting from a dead stop going straight and every time I shift I get the clunk sound as well. This rear end has been going out for some time, but I have just been babying it. Now though it has 240,000 miles and is getting ready to retire whether I like it or not. I have had the motor out a couple times, done the clutch a couple times, done wheel bearings, done the brakes about a million times, but I don't know squat about differentials and what it looks like in there. What could be happening in there by what I have described here? Any opinions?
Re: Times are tough,down on my luck and yippy...my rear end is going out [Re: Whatever] #737154 07/16/06 09:23 PM
4Crawler Offline
You may have a chipped gear tooth or two in there, probably as a result of the pinion gear loosening up. It is a piece of cake to swap out the differential (3rd member) with one from a junkyard, no special tools are needed. Just find one with the same gear ratio and you are set.
Re: Times are tough,down on my luck and yippy...my rear end is going out [Re: Whatever] #737155 07/16/06 11:56 PM
ZUK Offline
whatever----if you can take it out and ship it my way, then I will repair it at no cost to you except shipping. Shipping is 25 each way. Just a couple days turn-a-round. I'll post pics of the damage.
Ken Francisco
114 W Ivanhoe Place
Chandler AZ 85225 <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: Times are tough,down on my luck and yippy...my rear end is going out [Re: ZUK] #737156 07/19/06 03:07 AM
toyotaguy55 Offline
sweet zuks hooking you up <img src="/forums/images/graemlins/kewl.gif" alt="" />
toyotas look good with body damage
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6219 MB (Peak: 0.7135 MB) Data Comp: Off Server Time: 2026-11-02 07:43:16 UTC
