Wheels, tires, and gears #737291 07/13/06 10:14 PM
Cruizin Offline OP
Well I got done installing a 5.5" Rubicon Express lift on my 2004 Rubicon, got her aligned and she is looking kind of funny with the 33x11.50 inch tires on there. By the way that was a whole bunch of work getting that lift on there. Did it over the long 4th of July weekend and I don't know if I will every do another one. I want to go to 35" tires and 4.88 gears. I'm thinking of a 15" x 8" wheel. What would you guys do if you were me?
Re: Wheels, tires, and gears [Re: Cruizin] #737292 07/13/06 11:16 PM
Tikitgvr Offline
that is a good set up...I have a 6" lift with 37's and I will be running 4.88's
Re: Wheels, tires, and gears [Re: Cruizin] #737293 07/14/06 09:44 PM
Cruizin Offline OP
Oh by the way its a stick shift. What do you think the freeway driving will be like with the 4.88 and the 35" tires.
Re: Wheels, tires, and gears [Re: Cruizin] #737294 07/14/06 10:05 PM
BigJim Offline
If it is a six cyl you should be ok... A 4 banger will be puffing and panting..
Re: Wheels, tires, and gears [Re: Cruizin] #737295 07/15/06 06:42 AM
BobRowe Offline
Cruzin...
Your RPM at freeway speeds may be higher than you'd like for long distance. I have a TF999 auto tranny, an AMC 360 V8, 4.56 gears, and 35's. I limit my freeway driving to short runs because of the high RPMs.
Re: Wheels, tires, and gears [Re: BobRowe] #737296 07/15/06 02:28 PM
JeePete Offline
He'll have overdrive. You don't, do you? <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Wheels, tires, and gears [Re: Cruizin] #737297 07/15/06 02:48 PM
valleycat Offline
i would do 4.56's with 35's. i drove my buddy's tj with that setup. it seemed perfect. a little lower gearing would have been nice offroad with the 5 speed but you won't have that problem with 4:1 low range.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6180 MB (Peak: 0.6911 MB) Data Comp: Off Server Time: 2026-06-09 21:58:53 UTC
