What Rear Springs will fit a 1994 Toyota Truck ???
#737341
07/14/06 06:22 AM
I am needing to replace my rear springs on my 1994 3.0 V6 Extended Cab 4X4 Toyota Truck. One of the existing springs are cracked. My delima is that I know so little about the Toyota linup that I do not know what springs off of other vehicles may fit my truck.
After installing the new springs I would like to lift the rear about 3" so it will sit level with the front of the truck, like the new Tacomas do. Any recomendations on how to go about this? Blocks, Add a leaf???
If you are not living on the edge, You are taking up too much space.
Re: What Rear Springs will fit a 1994 Toyota Truck ???
[Re: JNetTrecker]
#737342
07/14/06 06:24 AM
BTW I am looking for fitting springs if you have some for sale.
[Re: JNetTrecker]
#737343
07/14/06 01:21 PM
BTW I am looking for fitting springs if you have some for sale. Then just get some aftermarket 3" lift springs. There are plenty of suspension lift manufacturers: Skyjacker, Rancho, All Pro, Marlin, Trail-Gear, etc
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 - '84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
[Re: fourwd1]
#737344
07/14/06 01:39 PM
Oh. Which is the least expensive Yet makes a good product.
[Re: JNetTrecker]
#737345
07/14/06 07:10 PM
The cheapest route would be to find some factory springs at a junk yard, and add some TJ coil springs aka the zuk mod. I've had a saggy '94 for years, and adding the TJ springs leveled it out perfectly. I think I paid 30 odd bucks off e-bay for the springs shipped to AK.
'94 extra-cab 3.0 extra slo (auto tranny) original owner. E/B o/s valve heads and no more crossover. More mods to come.
[Re: Paul_H]
#737346
07/14/06 09:58 PM
I ordered some new ones today. 3" lift. Hope they work out well. Got the whole kit and kaboodle (springs, busings, & u-bolts)for $310.00 Shipped.
[Re: JNetTrecker]
#737347
07/15/06 04:40 AM
You might be sitting a bit high in the back after installing those. The rear doesn't sit lower from the factory, it sags over time. Buying 3" lift springs should give you 3" over factory. Unless you have the front lifted already and I'm just dumb. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Where did you get the springs from?
I'm between toyotas right now... 3rd Gen 4-runner soon.
[Re: 92daily]
#737348
07/15/06 05:41 AM
Well in that case I might be screwed. I got them out of some place in Topeka KS. PM me if you want the information on the store. I measured 4" up from where I am now is level 5" is perfect and 6" is a little high (that is measured raising the rear bumper)
[Re: JNetTrecker]
#737349
07/15/06 02:50 PM
i have stock springs in my 89 pu one leaf is cracked on the passenger side... i added wrangler rear coils but it is really bouncy and a rough ride... should i cut the coils more? get softer coils? did u use front or rear wrangler coils?
tahnks kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!*** 1989 Toyota pickup 22re 5spd 4wd *** * New mods * - 305/70/R16 (33X12.5)
- 2 in suspention lift (zuk coils)
- minor body work
