cam timing question... #737453 07/15/06 12:37 AM
ToYPU Offline OP
My 22re's timing chain is aftermarket and it has no "bright links". so its like impossible to set the cam timing by the book... i just set the notch at what i thought was 11:30 but i dont think the motor is makeing the power it should... it wakes up and pulls after 3k i know its a 4cyl spinnin 33s wit 4:10s but i still dont think its there...
when the motor is cold... its peppy i think its cause the cold start injector is feeding it more fuel and once the motors warm and the csi shuts down its not getting enough fuel. can the 225k injectors be clogged causing this? or is it the cam timing?
thanks
kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
Re: cam timing question... [Re: ToYPU] #737454 07/15/06 08:45 PM
rednekbean Offline
From my experiances i have not had to use the "bright mark". In theory you shouldn't either, you just have to line up the mark on the cam to 12 0'clock and make sure you are on top dead center in the #1 cylinder. I also know from experiance that it is quite easy to miss a tooth on the cam sproket but that is a very noticable mistake.
I can say that to cheak the timing, first use the ditributor and a timing light (dont forget to disable the advance) and if you cant seem to get the mark in the right spot with only minor tweeking of the distributor than you need to investigate a little bit deeper.
Another note is if you have an aftermarket cam they some times need to be "degree'd". Now most quality cams already grind that in to the profile of the cam from their factory. There should be a booklet with the cam that explains how to do it if that is the case.
About the injectors with that much milage, well i just hope they have been cleaned sonner than 225k. How ever if they have not there are some over the counter cleaners( I.E. lucas fuel treatment) that have the right idea and work a little but if you really want your fuel rail and injectors clean try finding a shop with a Motor Vac, thats the name of the machine. and see if it fits your budget to have them do that to your motor. it will clean the carbon out of your motor to almost spotless, and i mean that. i have personally taken a motor apart that has had that done to it with ~200k with no other cleaning prior. The motor parts were damn near shinny. BTW the reason for the cleaning was poor runability and it helped but after the tear down the reason for the motor failure was the idgiot had RTV'd the hell outta the gaskets and the water passage's to the #3 cylinder were 3/4 blocked by Squished out RTV(the others were only half blocked <img src="/forums/images/graemlins/notooth.gif" alt="" />) so the cylinder over heated and blew the head gasket there.
One last note is that is also normal to see the power band of these 22r series motors litteraly kick in at 3-3500 RPM, thats normal operation, and they arnt know for there power either. Especially when you are pulling 33's with stock gearing.
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: cam timing question... [Re: rednekbean] #737455 07/16/06 03:57 AM
RatLabGuy Offline
Just a minor note - w/ the crank at TDC, the cam notch/hole is *just short* of 12:00, its more like 11:50 or so.
Question Reality.
Re: cam timing question... [Re: ToYPU] #737456 07/16/06 04:28 AM
A
atoyot Offline
So if it is off by one tooth, the ignition timing will be off and not correctable, or can you make the IT right? The guy I bought my truck from just did the timing chain (himself), and it's low on power, and I've checked everything (mostly). Good comp., Cat not clogged, plugs are new and burning nice, non-huge tires, air filter clean, etc. Could he have messed up the TC job, or would the truck not be low on power, but barely running?
Re: cam timing question... [Re: atoyot] #737457 07/16/06 04:36 AM
toyrunner Offline
Look to see if the pin for the cam gear is at 12:00 and the timing mark is at 0*. If when timing the ignition, the distributor isn't set about mid hole of the adjustment slot, chances are the cam is off, giving you the symptoms you have described.
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6088 MB (Peak: 0.6912 MB) Data Comp: Off Server Time: 2026-05-30 00:14:10 UTC
