Re: Strange vibration.
[Re: conner]
#737520
07/24/06 10:02 PM
No change on removing the belts. My brother did comment on the engine moving when I switched into drive or reverse. I looked at it and noticed the same thing. However, I don't know if this is normal or not. It rolls to the passenger side when you shift into rev. or drive. Heat shields appear tight, and skid plates where removed when I was last testing it, so it should not be them. The dipsticks at All Tune +Lube where the engine was installed say it's the rear diff vibrating; however they are not sure why the noise shows-up when revving in park.
[Re: ATCGuy]
#737521
07/25/06 12:11 AM
It is sounding more like the motor mounts than anything else- esp. since the movement you described.
98 Gen 2.5 05 Pontiac GTO 91 Corvette ZR-1 2011 Kia Sorento (wifey mobile) Clarkdale, AZ
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.5911 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-22 23:04:49 UTCValid HTML 5 and Valid CSS
