Mitsubishi 6G74, 3500cc, DOHC, 24 valve and it?s smoke issues. #737568 07/15/06 04:16 PM
A
arm755 Offline OP
I have seen in this forum and experimented it by my own SUV a 1995 Montero SR 6G74 engine with 230,000 miles, that this engine has serious smoke issues at every mileage. My SUV if I have the right engine oil level and leave it for about half a minute at idle speed It starts to smoke and smell (oil burning)like a hell. I haven't had time to dismantle the engine and look for the possible cause of it but I think that it can be or piston rings or oil seals, but searching for possible clues in this forum I readed something about a PCV valve.
Where can I start checking the cause of this oil burning?
Is there anything else in this engine that can cause this oil burning? Why does it burn oil only at idle speed? The first 1.5 liters of oil it burns it very quickly when at idle speed, then when the level of oil drops to about 3 liters it quite smoking. Why? I hope there someone who can help me out?
Re: Mitsubishi 6G74, 3500cc, DOHC, 24 valve and it?s smoke issues. [Re: arm755] #737569 07/15/06 06:35 PM
kiks Offline
Mine had similar symptoms. I changed the PCV but did not correct the oil consumption. It was only after I changed the Valve Seals that the excessive oil consumption stopped. In fact, it does not even use a liter of oil until the next oil change.
The engine ran smoother too after the Valve Seal change.
Hope this helps you.
Montero SR, 3.5 , 1995 model, ABS, Rear Differential Lock
Re: Mitsubishi 6G74, 3500cc, DOHC, 24 valve and it?s smoke issues. [Re: arm755] #737570 07/15/06 07:32 PM
LRJ4x4 Offline
It's a classic vavle seal problem, fairly painless fix <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Mitsubishi 6G74, 3500cc, DOHC, 24 valve and it?s smoke issues. [Re: LRJ4x4] #737571 07/17/06 05:03 PM
A
arm755 Offline OP
Thanks for your answers.
Can I change the 24 valve seals without having to dismantle the engine heads. Is there something I need to know?
Re: Mitsubishi 6G74, 3500cc, DOHC, 24 valve and it?s smoke issues. [Re: arm755] #737572 07/17/06 07:49 PM
W
Winston Offline
Yes, if you have about 40 hours to spare. I think someone posted a detailed procedure for your engine in the Mitsu Archive section.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6059 MB (Peak: 0.6707 MB) Data Comp: Off Server Time: 2026-06-17 04:06:15 UTC
