Help needed - Locked up transfer case #737728 07/16/06 02:13 AM
tgzzzz Offline OP
I bought an 87 Samurai that ran and shifted perfectly. I put the trans in 2nd, and the transfer case in N per the owners' manual, and towed it 20 miles home. When I tried to drive it, I moved the lever from N to 4wd, and it stuck somewhere in between and won't be budged. The lever will not shift at all. The front driveshaft is turning but I'n unable to move forward or back. What now?
87 JX Zuke bone stock almost cherry
86 Heavy Chevy 350 one ton 26' RV
There's always time to do it over.
Re: Help needed - Locked up transfer case [Re: tgzzzz] #737729 07/24/06 07:24 PM
Aaron84x4 Offline
you'd probably have more luck getting an answer by posting this in the suzuki forum...
84x4 Toyota Ext. Cab Deluxe
Not enough hours in the day to do what i want.....
.....and sleep
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5882 MB (Peak: 0.6361 MB) Data Comp: Off Server Time: 2026-06-22 14:17:58 UTC
