Silly but functional A/C idea.... #737747 07/16/06 07:11 AM
btn Offline OP
I have always thought about the possibility of installing a small household or rv ac unit in the rear sliding window during the summer months. It would be a lot less hassle and cheaper than installing a complete auto ac system. You may need a power inverter but a heavy duty alt would probably do fine with it.
I actually think it would be kinda slick.
Anyone ever seen this, what do you think?
1989 reg cab pickup, 22re, 31s, 4.56s, rear ARB, rear OME springs, RS9000s, otherwise stock.
Re: Silly but functional A/C idea.... [Re: btn] #737748 07/16/06 08:17 AM
L
lookmomnobrains Offline
i have seen it and it would work.(similar at least) if it were me to attempt this project, id cut out a piece of the rear cab wall and mount it low in the bed. the same piece that is cut out could easily be modified to mount back in place with a gasket of sorts to seal it.
roflmao....... <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: Silly but functional A/C idea.... [Re: btn] #737749 07/16/06 08:21 AM
Davepet Offline
Well, no not likely to work. If your AC unit draws 10 amps @ 120 volts you'll need 100 amps @ 12 volts, PLUS some since no inverter is 100% efficient.
Since presumably, you still want all your other electrical stuff to work, you'd need an alternater capable of putting out 100 amps more than your current one can (OK, I know you aren't using 100% of your alternator's capability now, but you get the idea, I hope).
Now what I've always though might work is to use the same type of system used in propane fired refigerators, but use the waste heat from the cooling system or exhast system instead of propane....
Dave
Re: Silly but functional A/C idea.... [Re: lookmomnobrains] #737750 07/16/06 08:21 AM
btn Offline OP
I don't know, seeing that picture....might be just a LITTLE too redneckish <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Silly but functional A/C idea.... [Re: Davepet] #737751 07/16/06 09:32 AM
tweedclassic Offline
two words "DUEL ALTERNATORS" <img src="/forums/images/graemlins/evil.gif" alt="" />
91 4runner 22re 5spd
Re: Silly but functional A/C idea.... [Re: btn] #737752 07/16/06 06:52 PM
abnormaltoy Offline
I hear the Sanford and Son theme in the background!
I'm comin Elizibeth.
I would rather suffer the consequences of a Conservative?s error, than suffer the consequences of a Socialist's intent.
Re: Silly but functional A/C idea.... [Re: abnormaltoy] #737753 07/17/06 04:15 AM
J94_4runner Offline
um, I'd go with fixing the factory a/C.
www.celicasupra.com
Re: Silly but functional A/C idea.... [Re: J94_4runner] #737754 07/17/06 07:10 AM
W
WolvesCross Offline
You think Toyota's have cold AC check out my first 4x4 i had when I was a teen. In the late 80's, my mom worked for a vending company. That would go around to job sites and sell different types of food. They had a AC unit on top of the truck to keep some of the food cold. I had a black 79 Dodge Ramcharger that would get so hot you could roast nuts in it. I took one of the AC compressors off one of the vending truck's that was broken down. Wired it up and ran the cooling hose right into the top of the Dodge. I could get it so cold in the cab that it would start to snow <img src="/forums/images/graemlins/lol.gif" alt="" />. I wish I had some pixs of that truck, it would be hard to pick out the AC compressor unit because i built a light bar and roof rack around it. You could write your name in the frost on the windows. Now thats cold AC
85 Toyota 4Runner SR5 4X4 4cyl. EFI(Procomp 4" lift)
Re: Silly but functional A/C idea.... [Re: lookmomnobrains] #737755 07/17/06 07:19 AM
kewlynx Offline
Man, I put that photo right up there with the car running around here with a cardboard grill and one headlight mounted in the middle. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
I'd be concerned about said piece of equipment flyin' up front while standing on the brakes myself........
On the mod....>coff< Fix the factory stuff as mentioned >coff<
**ubi apis- ibi salus**
Re: Silly but functional A/C idea.... [Re: btn] #737756 07/17/06 08:52 AM
TheBigDog Offline
Is your name Earl, and do you have a brother named Randy?
If so, I think your ex-wife is hot...in a slutty, skanky way. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Excuses are for losers.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6385 MB (Peak: 0.7629 MB) Data Comp: Off Server Time: 2026-07-15 08:01:17 UTC
