Did not Pass Smog - Help............ #737825 07/16/06 09:09 PM
DA4RNR Offline OP
Hey,
For the first time, my 85 4Runner did not pass smog (calif). I failed in the following:
NO (PPM)
...............Max Ave Meas
M1: 15mph 1090 406 1318
M2: 25 mph 1130 349 1288
I have read a few forms and have purchased a high flow cat conv and a new O2 sensor (still need to install both). Is there anythng else I should be doing? Thanks in advance!
Perminant Reminder of a Temporary Feeling
1985 4Runner w/ 3" NWOR Lift Kit
Detroit Lockers
Re: Did not Pass Smog - Help............ [Re: DA4RNR] #737826 07/16/06 09:16 PM
4Crawler Offline
High NOx is usually EGR related. Mine failed similarly. I pull the headers (or manifold) cleaned and ported out the EGR passages, cleaned the EGR valve and made sure that was all working 100%. Then I backed the timing off 3-4 degrees for the retest, filled with premium gas and dropped my NOx from 2200 down to about 800.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.5909 MB (Peak: 0.6388 MB) Data Comp: Off Server Time: 2026-11-18 03:40:43 UTC
