Rotor Replacement 3rd Gen 4 Runner
#738067
07/17/06 09:27 PM
I did do a quick search but I couldn't find anything on the rotor replacement for a 3rd Gen.
I'm thinking it is time, and if it is not too difficult I would like to attempt it myself.
Does anyone know of a write up somewhere on how this is done?
I had a 92 before, and I was told I would have to remove the front hub to do the job. Same with the 3rd gen?
Thanks for the help. This site is really a great source of info.
Tommy
Tom P 2000 4runner 5spd SR5 (pretty much stock) Bridgstone REVO(275/70r16)
Re: Rotor Replacement 3rd Gen 4 Runner
[Re: Tommytuttle]
#738068
07/18/06 03:01 AM
It's easier on a 3rd gen. Remove the wheel and pads. Remove the two large bolts holding the caliper on. Use a bungee to hold the caliper up and then just remove the rotor. The correct way to install new rotors is to check the runout with a dial gauge, if you don't have one it should be ok.
Milan _ _ _ _ _ _ __ _ _ _ _ _ _ Support our troops!
'98 4R Limited '82 Toy 4.3 TBI sold
[Re: Tommytuttle]
#738069
07/18/06 03:44 AM
Go to the Toyota section above, and look for the front end maintenance article there.
Also, there are a couple FSM's sticky'd in the Taco section that'll help you with the later model rigs. Your hubs will be different between this and your old 92, so that's key.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5935 MB (Peak: 0.6466 MB) Data Comp: Off Server Time: 2026-06-17 13:43:39 UTCValid HTML 5 and Valid CSS
