Rebuild a Montero Motor?
#738206
07/18/06 06:03 AM
Hi All,
I have a 2000 montero and it smokes more than it should. I want to replace to motor. Is it easier to replace with a crate motor or rebuild. I don't have the time to rebuild unless crate motors are not available. Thanks in advance, Ryan
90 Trooper 2.6 -Daily driver/backyard tractor-
Re: Rebuild a Montero Motor?
[Re: blue rig]
#738207
07/18/06 06:52 AM
Check with Rising Sun Motors, near Chico, CA.
[Re: blue rig]
#738208
07/18/06 12:41 PM
I'd investigate things like the valve seals before deciding to rebuild. Check your oil pressure, and compression in all cylinders, then report back. <img src="/forums/images/graemlins/wink.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
[Re: blue rig]
#738209
07/18/06 02:10 PM
And by all means, Save yourself and don't buy a Remanufactured engine, unless it has a 1 million mile warranty.
Good luck!
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: blue rig]
#738210
07/20/06 06:23 AM
Thank you all for the helpful reply. I will check things out mechanically before opting for a rebuild or new motor. Might have furthur questions depending on what I find. Thank you again. Ryan
PHP: 7.4.33 Page Time: 8.496s Queries: 15 (8.397s) Memory: 0.6028 MB (Peak: 0.6668 MB) Data Comp: Off Server Time: 2026-10-24 03:16:38 UTCValid HTML 5 and Valid CSS
