Rebuild a Montero Motor? #738206 07/18/06 06:03 AM
blue rig Offline OP
Hi All,
I have a 2000 montero and it smokes more than it should. I want to replace to motor. Is it easier to replace with a crate motor or rebuild. I don't have the time to rebuild unless crate motors are not available. Thanks in advance, Ryan
90 Trooper 2.6 -Daily driver/backyard tractor-
Re: Rebuild a Montero Motor? [Re: blue rig] #738207 07/18/06 06:52 AM
Check with Rising Sun Motors, near Chico, CA.
Re: Rebuild a Montero Motor? [Re: blue rig] #738208 07/18/06 12:41 PM
NathanC Offline
I'd investigate things like the valve seals before deciding to rebuild. Check your oil pressure, and compression in all cylinders, then report back. <img src="/forums/images/graemlins/wink.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: Rebuild a Montero Motor? [Re: blue rig] #738209 07/18/06 02:10 PM
87Montero Offline
And by all means, Save yourself and don't buy a Remanufactured engine, unless it has a 1 million mile warranty.
Good luck!
Re: Rebuild a Montero Motor? [Re: blue rig] #738210 07/20/06 06:23 AM
blue rig Offline OP
Thank you all for the helpful reply. I will check things out mechanically before opting for a rebuild or new motor. Might have furthur questions depending on what I find. Thank you again. Ryan
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6053 MB (Peak: 0.6692 MB) Data Comp: Off Server Time: 2026-10-22 04:05:04 UTC
