overdrive slippage #738901 07/20/06 03:51 PM
ddevitto Offline OP
I have a'02 grand cherokee, during normal highway driving the jeep downshifts frequently out of overdrive for a split second and kicks off the cruise control. This occurs even on flat surfaces not just on hills. I have taken it to two dealerships they acknowledge the problem but have no idea what is wrong with it. Any suggestions?
Re: overdrive slippage [Re: ddevitto] #738902 07/20/06 04:13 PM
BigJim Offline
What size tires are you running and what gears?
Re: overdrive slippage [Re: ddevitto] #738903 07/20/06 04:25 PM
Sounds like the brake switch is being triggered. I'd see if the brake switch is adjustable or if something is inbetween it and the pedal.
Re: overdrive slippage #738904 07/24/06 05:22 PM
ddevitto Offline OP
I will have that looked at for the cruise, but the engine still is downshifting out of overdrive for no reason. It is almost like it is sputtering and the plugs have been changed.
Re: overdrive slippage [Re: ddevitto] #738905 07/24/06 05:30 PM
BigJim Offline
once more dd... what size tires are you running?
Also changing the plugs is not a tuneup! What about the wires and coil?
Re: overdrive slippage [Re: BigJim] #738906 07/26/06 04:50 PM
ddevitto Offline OP
tires and gears are all stock, everything is still synchronized
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6074 MB (Peak: 0.6758 MB) Data Comp: Off Server Time: 2026-11-03 12:23:50 UTC
