overdrive slippage
#738901
07/20/06 03:51 PM
I have a'02 grand cherokee, during normal highway driving the jeep downshifts frequently out of overdrive for a split second and kicks off the cruise control. This occurs even on flat surfaces not just on hills. I have taken it to two dealerships they acknowledge the problem but have no idea what is wrong with it. Any suggestions?
Re: overdrive slippage
[Re: ddevitto]
#738902
07/20/06 04:13 PM
What size tires are you running and what gears? Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: ddevitto]
#738903
07/20/06 04:25 PM
Sounds like the brake switch is being triggered. I'd see if the brake switch is adjustable or if something is inbetween it and the pedal.
#738904
07/24/06 05:22 PM
I will have that looked at for the cruise, but the engine still is downshifting out of overdrive for no reason. It is almost like it is sputtering and the plugs have been changed.
[Re: ddevitto]
#738905
07/24/06 05:30 PM
once more dd... what size tires are you running? Also changing the plugs is not a tuneup! What about the wires and coil? Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#738906
07/26/06 04:50 PM
tires and gears are all stock, everything is still synchronized
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6074 MB (Peak: 0.6758 MB) Data Comp: Off Server Time: 2026-06-20 17:53:40 UTCValid HTML 5 and Valid CSS
