early signs of tranny probs? #738907 07/20/06 03:52 PM
ninety1troop Offline OP
Just wondering what those of you that have gone through transmission problems, noticed prior to it going "out". Seems like mine could be in "double-T-troubs". Over the weekend I logged about 600 interstate miles on it and the next morning when pushing the clutch in the truck didn't move. Typically it rolls back a bit. Noticing this as strange, I put it in reverse and slowly let out on the clutch. It popped (moderately loud) then went into reverse. No problems since (2 days) with this though. My truck is a 91 trooper, swapped 3.4, new clutch, bearing and plate (6 months ago), new clutch master and slave cylinder (3 weeks ago). Anyone had this problem? Thank ya.
"Some people never go crazy" - Burkowski
1991 Trooper, indy4x 1.5 lift, flowmaster exhaust, 3.4 engine swap.
Re: early signs of tranny probs? [Re: ninety1troop] #738908 07/20/06 05:33 PM
N
NotSoSimple Offline
Did you have good clutch pressure? First thought it the pedal was light, is that you need to bleed your clutch system.
'90 Trooper - 2.6L 5-Speed - 1" BL - Custom Roof Rack+2x55watt ProComp - Herculined Interior - Pace Setter Header - Dynomax Super Turbo - K&N - ProComp ES3000 Shocks - Optima Red - MSD 6A - 31" Kumho Mudders - Black Rock Crawlers
Re: early signs of tranny probs? [Re: NotSoSimple] #738909 07/20/06 06:18 PM
clutch pressure was ok. When we replaced to master and slave cylinders a couple weeks back, we bled the system really well I thought. In my personal opinion the clutch pressure could be better though.The pedal doesn't engage as high as it used to. But it shifts into gear just fine. This problem has happened before (month ago-similar situation), after a long drive and then sitting overnight.
Re: early signs of tranny probs? [Re: ninety1troop] #738910 07/20/06 07:26 PM
CPOM Offline
I think these manual transmissions are pretty tough, and you have to abuse them to weaken them. My other advice is to keep clutch operation and transmission problems seperate. Sometimes one gets diagnosed as the other. Sounds like you just have some clutch problems.
CHRIS
98 Amigo, 92 Pup
Re: early signs of tranny probs? [Re: CPOM] #738911 07/20/06 07:32 PM
N
NotSoSimple Offline
Have you checked both clutch fluid and trans fluid?
Re: early signs of tranny probs? [Re: NotSoSimple] #738912 07/21/06 04:23 AM
The clutch fluid is ok and I'm gonna go out on a limb and say that I'm not sure where to check the tranny fluid. Some couple of years ago I think I checked the tranny fluid and the rear end gear oil by pulling a bolt out and sticking my little finger in there. I ended up draining and refilling with fresh gear oil in the rear end but I can't remember about the tranny fluid for soem reason. I think I need to check the fluid level for sure. Thanks for that. Wish I just had a dipstick like the auto tranny. How often do you guys change the tranny fluid? Mine could very well need replacing.
Re: early signs of tranny probs? [Re: ninety1troop] #738913 07/21/06 06:02 AM
CPOM Offline
I change it every year, should be 5w30 eng oil
CHRIS
98 Amigo, 92 Pup
Re: early signs of tranny probs? [Re: ninety1troop] #738914 07/21/06 06:37 AM
trooperbc Offline
....I logged about 600 interstate miles on it and the next morning when pushing the clutch in the truck didn't move....No problems since (2 days) with this though.
....new clutch, bearing and plate (6 months ago), new clutch master and slave cylinder (3 weeks ago).
two things pop out to me
1.) the symptoms cry out that they are possibly heat related (long drive,cool down, etc.)
which leads me to
2.) no mention of a pilot bearing in your parts list for your clutch job.
which leads me to wondering if that could be binding (although you'd think you'd hear that if that was the problem).
thirdly, would be wondering if the throwout bearing is adjusted incorrectly, i.e. is it engaged (slightly) all the time spinning, heating up and 'freezing' on cool-down?
but you'd thnk you'd hear that, too.
(just some thoughts as i take a break from trying figure out my own (auto) trans problem). <img src="/forums/images/graemlins/confused.gif" alt="" />
good luck
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: early signs of tranny probs? [Re: trooperbc] #738915 07/21/06 05:21 PM
I have been hearing the throw out bearing making noise actually. And have questioned the way the guys installed the pilot bearing. He said that he had to freeze the pilot bearing before installing it for whatever reason. I only assumed the new clutch kit came with a new throwout bearing and he used it.
Re: early signs of tranny probs? [Re: ninety1troop] #738916 07/21/06 07:57 PM
N
NotSoSimple Offline
Hmm my Pilot Bearing used to make noise..It was because my tranys input shaft was worn and there was slop. I very carefully welded a bead on and emery clothed it down. Works great. It has been..25k miles? No problems! The noise went away too!
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.005s) Memory: 0.6353 MB (Peak: 0.7402 MB) Data Comp: Off Server Time: 2026-10-24 03:18:07 UTC
