just joined #739045 07/21/06 02:21 AM
teds280z Offline OP
I recently bought a '02 Sportage and when I went to check out some 4 wheelin I found the stock front bumper to stick out way to far. Damage done. Is there a different solid bumper that will mount on? Something that is flush with the front grill?
Re: just joined [Re: teds280z] #739046 07/21/06 02:32 AM
Calappoyas Offline
What I used to do (i run naked all the time now) is remove the front bumper whenever I would go 4x4ing. it's only 4 nuts, all in easy reach. takes less than 10 minutes to remove. Some of the guys on here hacksaw just off the air dam.
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
Re: just joined [Re: Calappoyas] #739047 07/24/06 12:52 PM
Dave Scott Offline
yeah, you can trim it, you can remove it, or you can put some bigger tires and a little lift on it and get it off the ground. there are a few bumpers available out there, but they are pretty much the same size as the stock one.
Re: just joined [Re: Dave Scott] #739048 07/24/06 10:38 PM
teds280z Offline OP
Thats what I was thinking. Do you know where to order different off road upgrade parts for the sportage?
Re: just joined [Re: teds280z] #739049 07/27/06 07:01 PM
flyboy367 Offline
i dont offroad so much, but i do beat the poop out of mine in bad weather responding to fire calls. i found that a 2" bodykit and relocating the bumper up works fine (but then again i bent mine coming from a 2ft jump <img src="/forums/images/graemlins/smile.gif" alt="" />) i would say since you offroad a 4" suspention lift and 31's would do you good.
1995 nissan maxima se, 5spd short throw, aluminum flywheel and crank pully, stage 3 clutch, custom ported top end, full 2.5 exhaust jdm front end
Re: just joined [Re: flyboy367] #739050 07/28/06 07:33 AM
Calappoyas Offline
31's rub the lower corners on the bumper. that's why I run naked all the time now. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: just joined [Re: Calappoyas] #739051 08/02/06 08:52 PM
logansportage Offline
No they don't! I've been running 31's for a couple of years now and I've only got the 1 3/8" body lift and the 2" spring lift from Eibach. I have relocated my bumber up to match the body lift and I'm still running the stock rims just to keep the tires inside the wheel wells.
Re: just joined [Re: logansportage] #739052 08/02/06 09:59 PM
Dave Scott Offline
and you still have your bumpstops......
Re: just joined [Re: Dave Scott] #739053 08/04/06 10:27 PM
Actually no, they rotted off just after went to Moab the first time.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6277 MB (Peak: 0.7301 MB) Data Comp: Off Server Time: 2026-05-29 22:44:34 UTC
