Calibrate torque wrench? #739139 07/21/06 01:28 PM
F
Fujisawa_Rob Offline OP
What are you using to test the accuracy of your clicker wrench? I used to have a beam type wrench to check it against, but it was stolen (sounds like the subject of a country music song: Ohhh, someone stole my torque wrench..). Any contraptions out there that you've built? Like a lever arm attached to weights, etc.?
I'm guessing that the adjustment is made by turning the set screw on the the ratchet arm. Is that right?
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Calibrate torque wrench? [Re: Fujisawa_Rob] #739140 07/21/06 02:40 PM
Mike Bridges Offline
Yes the adjustment is made at the bottom of the handle via the screw and lock nut. We use a digital torque gauge to set them up by. It's a real shocker to see how much they're off sometimes.
Re: Calibrate torque wrench? [Re: Mike Bridges] #739141 07/21/06 03:21 PM
F
What I meant was there's a allen head setscrew in the middle of the wrench body that screws into the ratchet head arm inside the hollow wrench body. Looks like the other end of the setscrew pushes against other wall of the tube. It would alter the angle of the ratchet head and alter the point at which it clicks as far as i can tell.
Re: Calibrate torque wrench? [Re: Mike Bridges] #739142 07/21/06 03:23 PM
W
Wayne Offline
How far to torque wrench is off, or how far the calibrator is off. ;-)
Make certain your source is calibrated occasionall as well.
In both the military and civilian jobs, we all push our calibration standards upward to be checked by a higher-level lab.
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: Calibrate torque wrench? [Re: Wayne] #739143 07/21/06 03:36 PM
FSJ1978 Offline
Gawd it would be nice to have a way to calibrate my torque wrenches without having to ship them off somewhere. If fish scales are fairly accurate it doesn't seem like it would be too hard to build your own test stand though it might get 'interresting' at higher torque loads as the arm got longer and longer
Chris Enos (Chino, CA)
'91 Isuzu Amigo "Rover" (Camaro 3800 swap in progress / 2.25" exhaust)
....(SOA / Custom rear bumper / CB / HAM)
Re: Calibrate torque wrench? [Re: FSJ1978] #739144 07/21/06 05:57 PM
F
I saw a site where a guy had a lever mounted in a vise with an arm of known length and a measured weight on the end (barbell weights that he measured on a digital scale). I'm not sure how he had the vise set up - I'd think you'd need an outer tube to grip and an inner shaft, and a couple of bearings. Basically a scale or balance, with the wrench forming the other "arm".
Re: Calibrate torque wrench? [Re: Wayne] #739145 07/21/06 07:20 PM
W
Wayne Offline
How far to torque wrench is off, or how far the calibrator is off? ;-)
Make certain your source is calibrated occasionally as well.
In both the military and civilian jobs, we all push our calibration standards upward to be checked by a higher-level lab. [/quote]
Re: Calibrate torque wrench? [Re: Fujisawa_Rob] #739146 07/21/06 07:21 PM
W
Wayne Offline
For home use, I'd think +/- 10% would probably be ok.
Most people don't pull the wrench correctly, anyway, screwing up the torque value. Or my favorite, "And a little extra for good meansure."
Re: Calibrate torque wrench? [Re: Wayne] #739147 07/21/06 11:38 PM
Gizzy42 Offline
Usually there is a torque range instead of one specific value (not always though, IE IMG gaskets) so I normally set mine for the middle of the range. That way if its off a little (most likey) theres a good chance of being within range.
Anything under 20 ft lbs I use an inch lb wrench. More accurate at low values then a ft lb wrench.
Would like to get mine calibrated though.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Calibrate torque wrench? [Re: Fujisawa_Rob] #739148 07/22/06 12:13 AM
P
pplotz Offline
I found one at my nearest discount tire and mine was dead on, just ask at a shop near you that uses them a lot, they'll have something that you can use to check it.
PHP: 7.4.33 Page Time: 0.020s Queries: 16 (0.017s) Memory: 0.6420 MB (Peak: 0.7626 MB) Data Comp: Off Server Time: 2026-10-25 20:12:49 UTC
