Re: Calibrate torque wrench? [Re: Fujisawa_Rob] #739149 07/22/06 05:59 AM
litnin Offline
If you want to do it correctly and accurately, you
need a torque tester/calibrator.
Be prepared to spend anywhere from $1600-$1800 for one.
http://buy1.snapon.com/catalog/item...;group_ID=986&store=snapon-store
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Calibrate torque wrench? [Re: Wayne] #739150 07/22/06 09:56 PM
Mike Bridges Offline
How far to torque wrench is off, or how far the calibrator is off. ;-)
Make certain your source is calibrated occasionall as well.
In both the military and civilian jobs, we all push our calibration standards upward to be checked by a higher-level lab.
We are one of the higher-level labs. I've seen a little oops dropped it change one 25-30 lbs. We had a never used out of the box off by 125 lbs. We usually use inch lbs for anything under 15 foot lbs.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.5929 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-10-25 20:12:42 UTC
