another no-slip locker installed #739239 07/21/06 08:57 PM
fishy97t100 Offline OP
i just finished installing a powertrax no-slip locker in the rear and tested it. i didnt have to remove the brake line to pull the shafts far enough for the 3rd member to come off.
the tires seem to be getting dragged when turning. is this normal? do tires wear out faster if you have a locker?
Re: another no-slip locker installed [Re: fishy97t100] #739240 07/22/06 03:12 PM
jmoser Offline
With mine I found that I had to learn to glide into turns, foot off gas while turning, apply power once wheels were straightened out. Off pavement I drive any which way I want!
I broke in for ~3K with conventional lube, drained and refilled with Mobil 1 75W90. Seemed quieter and smoother after the refill.
P.S. Be careful on wet or slippery pavement, you can kick out the rear end sideways when stepping on the gas! I almost took out a toll booth on the OH turnpike with some wet slush on the ground last Xmas.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: another no-slip locker installed [Re: jmoser] #739241 07/24/06 05:51 PM
ErikB Offline
Toyota Moderator
Coasting in turns the tires shouldn't scrub, but when you apply power it will lock and then act like a spool.
http://home.4x4wire.com/erik
Re: another no-slip locker installed [Re: ErikB] #739242 08/07/06 06:11 AM
...500 miles now, i dont hear any clicking anymore. ive taught myself to coast on turns to minimize tire scrubbing on road.
i shouldve put this on sooner. it works like wonder off road. ..works well in sand too
1997 T100 SR5 xxcab 4WD 5spd D44, AAM 11.5, dual case
Re: another no-slip locker installed [Re: fishy97t100] #739243 09/07/06 02:23 AM
Jake97T Offline
im about to order the soft locker, wondering if anybody has a good source besides allpro, looks like they're being sold for around $495 everywhere...
Re: another no-slip locker installed [Re: Jake97T] #739244 09/07/06 05:02 AM
MisterZee Offline
we installed a lockrite onto one of our Yota's this summer, and it behaves Xactly the same way.
98 Taco 4WD
Re: another no-slip locker installed [Re: MisterZee] #739245 09/07/06 05:33 AM
Jake97T Offline
i wonder if ill get the same strength from a lunch box locker???
Re: another no-slip locker installed [Re: Jake97T] #739246 09/07/06 08:18 PM
I got my no slip from rocky-road.com for under $400, if you're thinking of getting the lunch box instead. Im not sure if they have a lockrite for the rear, but they do have one for the front for under $300
roadtrip pics - 4 corners region area [Re: fishy97t100] #739247 04/05/07 09:46 AM
Inspired by KC's pics (Creeper), I ventured out for a solo trip...went to see the canyons for the first time and explored the area as much as I can in little time. 6 days - 3000 miles.
Got few big pics and a cheesy video (Hell's Revenge, Moab) to share http://www.youtube.com/watch?v=Qa8hyIkuUb0
[EDIT by ErikB]
See new thread for pics:
http://www.4x4wire.com/forums/showflat.php?Cat=&Number=993126
Re: roadtrip pics - 4 corners region area [Re: fishy97t100] #739248 04/05/07 05:26 PM
ErikB Offline
Toyota Moderator
GREAT pics! <img src="/forums/images/graemlins/kewl.gif" alt="" />
You should start another thread and post more!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6387 MB (Peak: 0.7632 MB) Data Comp: Off Server Time: 2026-06-07 08:27:33 UTC
