Question about Bridgestones. #739319 07/22/06 02:33 AM
Don Tibbetts Offline OP
I'm getting new tires for my 97 T 4WD. I do most of my driving on the road (~90%). I don't do any serious off-roading, not intentionally anyway. Sometimes it does get a little hairy when we're scouting out new hunting spots but I don't look for trouble.
I have Michelins on both of my vehicles now and am very pleased with them but I have the wandering eye. I know that a lot of you run Bridgestone Revos and love them. My big question concerns how well they keep their balance. I've had the Michelins balanced once in the 23K that I've owned the truck and that's because they were out of balance when I bought it.
I'm trying to weigh my options because I believe I can get the tires for about the same price but I'm moving soon and if I go with our local tire store, which I really like, I'll be paying for balancing after I move. If I buy from Sam's, I'm covered for the life of the tires.
If you're still reading, thanks for hanging in there. Hopefully you can help me make my decision.
97 T100 4WD SR5 - 231K
Re: Question about Bridgestones. [Re: Don Tibbetts] #739320 07/23/06 03:07 PM
Dandeman Offline
Toyota Moderator
I've got 38,000 on my Bridgestone Dueler ATs and have not had any need to rebalance them. I'm also a long time Michelin tire user and was cautious (and concerned) about going non Michelin.
I've been very pleased with them... outstanding performance with regard to not hydroplaning in standing water..
The only caution (and in my experience, this is true with any wide tread tire with large, deep tread blocks that have tread pattern cuts running across the tire from side to side) is rotate them say every 5-7k miles from front to rear and, especially make sure your front end alignment is perfect (particularly make sure it has only the minimally required amount of toe-in) to avoid outer edge, leading/trailing tread block wear at the front.
I measure my tread depth across the tire every time I change the oil and, if there's any significant difference in depth, it's time to rotate them so the wear evens out on the rear.
Re: Question about Bridgestones. [Re: Dandeman] #739321 07/24/06 02:46 AM
Thank you. I was worried about going away from Michelins only to find that the Revos would need balancing every 10K miles. Good advice on checking tread depth too. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Question about Bridgestones. [Re: Don Tibbetts] #739322 07/24/06 12:17 PM
jabush Offline
I have been pleased with my Bridgestone Dueler AT's as well. Quiet on the highway, good grip in rain/snow, and they seem to be wearing well. I also rotate mine with every oil change (front to back).
joel
*1996 T100
2wd,long bed w/5speed
Borla Cat-back
*2002 Z28 Convertible
*2002 Lightning
*2005 Trailblazer
Re: Question about Bridgestones. [Re: jabush] #739323 07/24/06 05:54 PM
ErikB Offline
Toyota Moderator
Only time I have to rebalance is when I lose a weight (not the tire's fault). <img src="/forums/images/graemlins/notooth.gif" alt="" />
I generally rotate with oil changes (5k) as well.
http://home.4x4wire.com/erik
Re: Question about Bridgestones. [Re: ErikB] #739324 07/27/06 11:44 AM
Thank you gents. I will be calling the tire store today to check price and availability, work permitting.
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6134 MB (Peak: 0.6847 MB) Data Comp: Off Server Time: 2026-11-19 23:57:17 UTC
