Will This work with a tarus fan?
#739717
07/24/06 01:37 AM
I am selling my red rodeo. Right now I turn the fan on manually. but I need it to be thermostaticallly controlled. I heard the tarus fan pulls 60 amps on the start and this is only thirty amp I can't find anything bigger. I am not looking to spend a lot of money since I'm getting rid of it. I just don't think the new owner will wan't or will remember to turn it on manually. A MUCH SHORTER LINK
94 Rodeo 3+3 lift Red) 95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2 front winch bumper custom rear bumper, Hella 500's 2004 Silverado duramax
Re: Will This work with a tarus fan?
[Re: 94redrodeo]
#739718
07/24/06 02:37 AM
If your just looking for a bigger capacity relay, scroll to the bottom of this page: 70 amp RelayThis one says it request special connectors, I can't imagine what would be that special. Just letting you know they are available.
[Re: lttlbddy]
#739719
07/24/06 04:13 AM
So if I use a 70 amp relay and a 60 amp fuse with this kit you think it will work okay
[Re: 94redrodeo]
#739720
07/25/06 04:06 PM
A Not So Horrendously Long LINKUse that kit with a high amp relay.
1996 Rodeo 3.2l 4wd 3" Indy4x lift - 3" Body Lift - Calmini torsion bars - Superwinch hubs - Independent4x brake lines - 32x10.5x15 Pro Comp MT's - Flowmaster 2.5" cat-back - Indy4x Tie Rods - Rear Lockright
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6004 MB (Peak: 0.6566 MB) Data Comp: Off Server Time: 2026-10-26 04:11:19 UTCValid HTML 5 and Valid CSS
