Help with Howell TBI Conversion #740599 07/27/06 12:31 AM
RLBomber Offline OP
So far, the conversion is going pretty good for someone with little experience with this.
Anyway my question is this: The instructions state to remove the Upstream & Downstream check valves. But it doesn't state what to do with the pipes once they are removed.
These valves are connected to exhaust pipes and I'm not sure what I'm suppose to do with these once there removed. I believe on pipe goes to the catalytic converter and the other pipe goes to the exhaust manifold. There is also a small diameter red hose that looks like it runs to the converter.
Thanks in advance for any help.
Rlbomber
Re: Help with Howell TBI Conversion [Re: RLBomber] #740600 07/27/06 01:20 AM
Just plug them. They sell high temp epoxy that will withstand the temp and pressure. Or you could crimp them off and weld them...
Re: Help with Howell TBI Conversion [Re: RLBomber] #740601 07/27/06 06:44 AM
Another post with no vehicle information.....
Hardware stores sell pipe plugs that you can put in the exhaust manifold.
Re: Help with Howell TBI Conversion #740602 07/27/06 11:19 PM
superdawg Offline
If you are in a emissions testing area, following Howells instructions will get you failed on your next test.
These systems don't like AIR blowing on the o2 sensor, so they have to go away... however in Colorado.. we can have the rig recertified for the later model TBI system that legaly allows for the AIR system to be completly removed.
You must have the VSS, P/N switch, brake switch operational and no codes coming up for anything to get the recert.
SD
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.5932 MB (Peak: 0.6511 MB) Data Comp: Off Server Time: 2026-11-18 11:53:35 UTC
