Gen 2.5 Pajero V6 3.0 6G72 engine Fluctuating Idle #740695 07/27/06 11:32 AM
A
Aldee Offline OP
Hello everyone.
I just bought a Pajero V6 3.0 6G72. Im having problems now with the fluctuating idle. I have cleaned the throttle body, idle speed controller, air flow sensor(just after the air cleaner). changed spark plugs,changed fuel filter, changed air hose, adjusted engine timing to specs. and still im getting fluctuations on my idling. i even have it diagnosed at the dealer with their Mut-1 or Mut 2 but to no avail.
what could be my problem?
Can anyone please help me???
Re: Gen 2.5 Pajero V6 3.0 6G72 engine Fluctuating Idle [Re: Aldee] #740696 07/27/06 02:08 PM
Macka Offline
Aldee check the big air hose from the air cleaner to the throttle body for leaks. If its cracked or has small holes it'll mess with the idle. If you have a spare just swap it out. If thats not the case, check you O2 sensor, sometimes it has a faulty connection.
always working
Re: Gen 2.5 Pajero V6 3.0 6G72 engine Fluctuating Idle [Re: Aldee] #740697 07/27/06 05:22 PM
CapnCrunch Offline
Also check to see if your EGR valve is stuck open / plugged with carbon build-up. That can cause an erratic idle.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Gen 2.5 Pajero V6 3.0 6G72 engine Fluctuating Idle [Re: CapnCrunch] #740698 07/28/06 04:42 AM
A
Aldee Offline OP
Thanks for the suggestion....i dont have a manual yet, can anybody tell me where the o2 sensor is located?? and where the egr is located???
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6005 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-06-22 23:01:09 UTC
